7.3 no start issue
Old Nov 20, 2017 | 12:00 AM
  #46
jungles82's Avatar
jungles82
What does it look like when the injectors are squirting? I'm not seeing any oil circulating around the Injectors or anything I also went and checked wiring and a few other things I love the obs trucks but man im missing the simplicity of my old 12 valve cummins. Does anyone know anyone that has a snap on scanner around in Oregon that could scan this for me?
Old Nov 20, 2017 | 10:36 AM
  #47
knottyrope's Avatar
knottyrope
just a small spurt of oil comes out from the little metal spout
Old Nov 20, 2017 | 11:29 AM
  #48
jungles82's Avatar
jungles82
Yea I got nothing do u think it's th hpop? Is there an electric fuel pump on them somewhere?
Old Nov 20, 2017 | 12:37 PM
  #49
knottyrope's Avatar
knottyrope
HPOP don't usually just go
Can pressure test HPOP but need a 0-4000 PSI gauge for it or use a scanner if ICP is ok
These has a mechanical fuel pump unless upgraded to efuel
Old Nov 20, 2017 | 11:04 PM
  #50
jungles82's Avatar
jungles82
Will it still read if the icp sensor is bad mines leaking oil out of it a little
Old Nov 21, 2017 | 02:05 PM
  #51
knottyrope's Avatar
knottyrope
if leaking bad, they can read wrong pressure
Old Nov 21, 2017 | 02:17 PM
  #52
jungles82's Avatar
jungles82
It's not horrible just a little oil in it
Old Nov 21, 2017 | 08:04 PM
  #53
z31freakify's Avatar
z31freakify
If theres oil in the plug you will get a bad reading.
Old Nov 21, 2017 | 08:53 PM
  #54
jungles82's Avatar
jungles82
Will it still show a reading though?
Old Nov 22, 2017 | 06:34 PM
  #55
jungles82's Avatar
jungles82
So I only have about 9psi after cranking for 45 seconds and it passed an injector buzz test when I have a better internet connection ill post pictures of the scanner I had hooked up and all the stuff it said
Old Nov 22, 2017 | 07:37 PM
  #56
jungles82's Avatar
jungles82
So with all this data what do you guys think is the fuel pressure to low and I need a fuel pump or an hpop or idm or what?
Old Nov 23, 2017 | 01:26 PM
  #57
jungles82's Avatar
jungles82
Anyone got any ideas?
Old Nov 23, 2017 | 07:55 PM
  #58
jungles82's Avatar
jungles82
I also did the bb mod when I resealed the fuel bowl
Old Nov 23, 2017 | 09:31 PM
  #59
Red97350's Avatar
Red97350
Why are the measurements in metric? The scanner can't tell fuel pressure, so don't go by what the scanner shows for it.
Red
Old Nov 24, 2017 | 12:19 AM
  #60
jungles82's Avatar
jungles82
No i tested the fuel pressure with a gauge on the port on the fuel pressure regulator. I didn't even notice it was metric and any idea why it took so long while cranking to build pressure I'm also gonna put a gauge on the fuel line going into the head. I will rescan it tomorrow and get the results in standard not metic
