Trans fluid temp sensor
Old Jul 10, 2017 | 05:49 PM
Mikenski's Avatar
Mikenski
07 f250 with 149k, my trans gauge spiked at 176, and then went all over, now reading 0 temp, question is where is the sensor located
Old Jul 10, 2017 | 08:04 PM
wedge542's Avatar
wedge542
Maybe this will help=https://www.ford-trucks.com/forums/1048321-p0713-tft-sensor-failure-replacement.html
Old Jul 10, 2017 | 09:48 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's clipped to the solenoid body inside the pan.
Old Jul 10, 2017 | 09:49 PM
Mikenski's Avatar
Mikenski
Ok I'll look into it thanks, dash wise my tow haul light flashes, check engine light on, and the codes showing are p0700,p0710,and p0713
Old Jul 11, 2017 | 10:07 AM
bismic's Avatar
bismic
https://cimg5.ibsrv.net/gimg/www.for...9941fde2be.jpg
Old Jul 11, 2017 | 12:22 PM
wedge542's Avatar
wedge542
Thanks mark,not sure why my post of that did not come up as a link, thats never happened before on this site.
Old Jul 11, 2017 | 08:04 PM
Yahiko's Avatar
Yahiko
That is odd that your post of the URL did not come up with a link.
https://www.ford-trucks.com/forums/1...placement.html
The = after help needed to have a space before the HTTPS
See how it fixed it when I quoted your post after I placed the space.
Sometimes doing HTML can be a pain in the @ even when your used
to doing some of the odder things. I still have to use a cheatsheet
with some things.
At least when it comes to trans work doing the temp sensor is not too bad of an ordeal.
Just keep things clean and the pan gasket is reusable if not distorted. Also if you have
not done it yet now would be the perfect time to do the 6.4 Pan and filter upgrade.
They are down to $59.13
Trans Pan for 2008 Ford F-350 Super Duty|8C3Z-7A194-B : AutoNation Ford White Bear Lake | Parts & Accessories
and the filter is $42.31
Filter for 2008 Ford F-350 Super Duty|8C3Z-7A098-D : AutoNation Ford White Bear Lake | Parts & Accessories
I removed some # do to there being some question on what they were for.
Old Jul 11, 2017 | 08:17 PM
bismic's Avatar
bismic
post deleted
Old Jul 11, 2017 | 08:29 PM
Yahiko's Avatar
Yahiko
I am going to remove the questionable #s so I don't screw someone up.
hanklin
Jun 26, 2017 03:28 AM
mickpowell1967
Aug 22, 2013 08:09 PM
kx450frider617
Mar 20, 2013 11:46 PM
swampfire79
Jan 28, 2012 04:17 PM
