transmission problem! need help ASAP
Old Mar 20, 2013 | 07:37 PM
kx450frider617's Avatar
kx450frider617
I was driving the truck and the "tow/haul" dash light starts blinking, the "check gauges" light is on, and the "check engine" light is on. Also, the trans temp gauge on the dash is all the way down.
The truck shifts fine, the tow haul mode seams to work fine. Im thinking its a trans temp sensor. What are your opinions? Thank jordan.
Old Mar 20, 2013 | 08:22 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Pulling codes would be the next step. A basic reader may not get them all, especially the ABS codes. Maybe something snagged the trans harness under the truck? Or squirrels have been chewing on it?
Old Mar 20, 2013 | 08:32 PM
BLADE35's Avatar
BLADE35
A bad TFT sensor will throw truck into limp mode
need to see that sensor to see Hiw Bad Its Jumping around
Old Mar 20, 2013 | 08:52 PM
Rusty Axlerod
Woulda swore I read ABS in there somewhere. Check gauge light is on because of the trans temp. Could tow/haul flash for the same reason? So the dash can light up like Christmas because the trans temp sensor is out but you can melt down the engine without the first indication of any issues on the instrument panel...wow
Old Mar 20, 2013 | 09:02 PM
Yahiko's Avatar
Yahiko
FTE Remembers
You need to scan for stored codes.
Like Rusty said the cheaper readers don't get all the codes some times.
That also goes for the "FREE" reading that they do at places like Autozone.
It's a case of you get what you pay for. If you were close by I would say
come on over and I can scan it with my Snap-On Solus. That invitation is open
for anyone with a 6.0 that is near by.
Sean
Old Mar 20, 2013 | 09:36 PM
BLADE35's Avatar
BLADE35
rusty when my TFT acts up the Gauge would MAX the Check Gauges would Light up it would go into limp mode
No CEL
On the SGII TFT would read 85* Then Bounce to 7K-8K then back and forth
The Dash Gauge wouldnt show The Half of it
Old Mar 20, 2013 | 09:43 PM
kx450frider617
If it is the temp sensor, is it okay to drive back home, about 100 miles. The truck drives normal. The only thing I noticed was the dash lights.
Old Mar 20, 2013 | 11:46 PM
04badford's Avatar
04badford
Hows the fluid level and when was the tranny serviced?
Mikenski
Jul 11, 2017 08:29 PM
Neal 97 250
Aug 10, 2015 07:05 PM
mickpowell1967
Aug 22, 2013 08:09 PM
Joms
Apr 18, 2010 06:36 PM
