Dashcam mounting
Old Jul 13, 2017 | 11:19 AM
  #46
glrret's Avatar
glrret
Originally Posted by EpicCowlick
I have a Viofo and really like it. The GPS module is a little rectangular box that the dash cam clicks onto. Power cable goes into it from the top which makes for a very clean looking install. The module simply stamps the recorded video with location and speed information. When you play back a Viofo video file it will include that info in the meta data. Without the GPS module you just get video. Some people prefer no GPS so they won't get caught speeding in the event they need the video file for insurance purposes. There is no connection to the truck's GPS.
EpicCowlick, Thank you for your explanation, that clears up all questions that I had, but creates another one. can the GPS marking feature be disabled by simply disconnecting the small cable?
Old Jul 13, 2017 | 12:28 PM
  #47
EpicCowlick's Avatar
EpicCowlick
All you do is remove the GPS unit and plug the power cable directly into the side of the Viofo. The recorded video will no longer have the GPS information embedded into it.
Old Jul 13, 2017 | 12:35 PM
  #48
Tricon's Avatar
Tricon
Someone else asked about this, so I thought I'd share for future lookers. If you want to wire it up as I posted above, here's the wiring diagram for the upfitter switches so you can tell what wire goes to what switch.
https://www.fleet.ford.com/truckbbas/non-html/Q-252.pdf
Old Jul 13, 2017 | 01:03 PM
  #49
LCC's Avatar
LCC
Originally Posted by flanneljunkie
Viofo a119s mounted in a 2017 f350
Originally Posted by railrode1
This is where I mounted my Viofo also, but on the right side of the mirror.
Same thing I did with mine.. right side.
As a side note. I did have a problem with the GPS mount while driving. The camera would turn the display on and off. Moved the connector to the camera itself (by passed the GPS module) and it stopped doing it. I'm assuming that the connector on the mount is bad..
Old Jul 13, 2017 | 02:09 PM
  #50
flanneljunkie's Avatar
flanneljunkie
Originally Posted by bushpilot
Mounting it on the left (drivers) side of the mirror could block the sensor in the back of the rearview mirror...there is no sensor on the right (passenger) side.
For what it's worth, the spot that I mounted my dashcam did not have any effect on the lane keeping sensor. Either way, I don't use the feature so it wouldn't have bothered me if it did disable it.
Old Jul 13, 2017 | 02:15 PM
  #51
Robeleo's Avatar
Robeleo
Yes, it's an common issue, great dash cam anyways. Mine used to do the same thing and was driving me crazy, then I saw a video on YouTube that a guy used a zip tie between the GPS module and camera in the right side and I did same thing and it works
I can shoot a picture when I get home if you need to
Old Jul 13, 2017 | 02:34 PM
  #52
bushpilot's Avatar
bushpilot
the sensor in the back of the mirror is not related to the lane keeping or lane departure warning.
the sensor in the back side of the mirror is for auto dimming of the mirror (and likely but unconfirmed the auto-dimming headlights).
as confirmation (during daylight) I covered the sensor in the back of the mirror and it did not affect the lane departure warning system at all.
Old Jul 13, 2017 | 02:55 PM
  #53
flanneljunkie
Probably explains why my auto-highbeams didn't seem to work.
Old Jul 14, 2017 | 10:52 PM
  #54
Robeleo's Avatar
Robeleo
Mine work great and I have it mounted there
Old Jul 15, 2017 | 08:32 AM
  #55
Sleepyguy's Avatar
Sleepyguy
Can you all do some explaining for dummies. What is required to power the truck. How exactly did you wire it up?
I am looking at a cam and seems like it's going to cost me a pretty penny to have anyone do it let alone buy a camera from them. I have been quoted $800 camera and install.
Old Jul 15, 2017 | 08:42 AM
  #56
railrode1's Avatar
railrode1
The Viofo is around a $100. It comes with a 10 ft USB cable. It was long enough to go across the headliner, down the a Piller, under the dash and plugs in an outlet in my center console (all on the passenger side). It's switched by the key. Very simple and cost effective with quality video.
Old Jul 15, 2017 | 09:00 AM
  #57
EpicCowlick
You just described my setup except I ran the wire down the driver side and into the center console. Piece of cake and wires are all hidden unless you go looking for them.
Old Jul 15, 2017 | 09:23 AM
  #58
Sleepyguy's Avatar
Sleepyguy
What about hardwiring to allow for security parking mode? It is to my understanding there is fuse panel passengers side of the dash?
My truck is getting whole wiring harness replaced along with BCM. I figured this might be a good time to get a wire ran or installed as truck will be in pieces to start with.
Old Jul 15, 2017 | 10:46 AM
  #59
bushpilot's Avatar
bushpilot
I found an always on circuit in the passenger side/kick panel and wired to that hot circuit (always on) for my Thinkware F770 dash cam.
Wiring is easy....just tuck the wire in the windshield header / head liner....then pop the a-pillar cover off (you'll need to remove the grab handle but un-unbolting it)...then fish the wire down to the kick panel where the fuse panel is on the passenger side kick panel.
Essentially my camera never shuts off, the Thinkware F770 has a (programable) low voltage threshold that will turn the camera off (when voltage drops to a certain threshold) to prevent draining of the battery.
Old Jul 16, 2017 | 07:20 AM
  #60
livkot's Avatar
livkot
A forum member recommended the unit I installed. My highest want was a unit with no screen and a small profile. It attaches to windscreen with a plastic receiver secured with double side tape. I did need to relocate it after initial install and it required quite some effort. One year in the sun? Who knows.
