300ci head/ intake questions
I recently bought an 89 f150 w/ a 300 inline 6. The factory EFI system is a mess and I'm seriously thinking about converting it to an offenhauser intake manifold w/ 4bbl carb or tbi fuel injection.
Is my head compatible with the offenhauser intake?
Has anyone done this conversion? I searched the forum and see a few people running the offenhauser intake. Suggestions are appreciated... thanks
The only issue you may run into is your exhaust manifolds getting in the way of the Offenhauser intake. I've had two Offenhausers, and when I installed both of them for the first time, along with the exhaust manifolds from an EFI era engine, one of the hanging loops always gets in the way and I have to grind it off.
The EFI head has 16 bolt holes as opposed to 13 of the carb'd head. The 3 extra are simply to hang the manifolds from during installation (which is why they're a full loop instead of just a tab) so removing one of them won't hurt anything.
I also usually have to grind down a few spots on one of the runners in the exhaust manifold for clearance, or else it keeps the intake from fully seating against the head (instant recipe for snapped tabs).
Either way, it's easy to do, and about 5 minutes with a good grinder. Just make sure both the exhaust manifolds and the Offenhauser will sit flush against the head without a gasket before installing. If not, find out what's binding and remove it.
kas83
04-27-2012 03:14 AM
