Offy / Headers q?
Old Jun 8, 2017 | 10:14 AM
IppoJ's Avatar
IppoJ
Offy / Headers q?
I've searched and think I know the answer but wanted to verify.
Previous owner installed headers on my 4.9l, do I need to remove those to install the Offy DP manifold?
Any suggestions on what is best to use for the thick washers?
Thanks
Old Jun 8, 2017 | 10:28 AM
AbandonedBronco's Avatar
AbandonedBronco
Hi Ippo,
Are you saying that they installed headers with the stock 1bbl carb intake?
Either way, yes, the intake and exhaust share the same bolts to hold them on, so to remove one, you always have to remove the other. On this engine, that's a given no matter what intake/exhaust combo you have.
For thick washers, the stock ones work well if you have enough meat on the mounting tabs (I've always found them to be a little too small in diameter).
Otherwise, these are the ones I use, and I like them:
https://www.nutty.com/EXTRA-THICK-Gr...ers_c_427.html
I got a mix of 1/2" and 9/16".
Too thin of a washer, and it'll curl under the torque.
Old Jun 8, 2017 | 01:58 PM
IppoJ's Avatar
IppoJ
Originally Posted by AbandonedBronco
Hi Ippo,
Yes, exactly.
Perfect, thanks for the reply.
next search: ripping out the emissions extras. or more accurately, what little is left of them.
mycods
19
Feb 2, 2022 06:02 PM
kgh
Mar 13, 2013 11:52 PM
1984F15016
Jul 28, 2005 02:35 AM
grappledad
Sep 19, 2004 08:18 PM
