Boost problem *** UPDATE ***
Old Feb 19, 2017 | 06:56 PM
  #46
WatsonR's Avatar
WatsonR
Sorry, been busy. Check the intercooler plastic inlet and outlet? And on the pressure side boots where it's reinforced with the spiral wire.
I'm doing a turbo swap tomorrow, I'll check the thread. I've been on a phone only, can't see a zip file very well, it's a jumbled mess of numbers.
Old Feb 19, 2017 | 07:00 PM
  #47
Will Bite's Avatar
Will Bite
I did today. Have the metal tubes and new boots. No hurry your help is appreciated. Can't complain if it's free. Lol
Old Feb 19, 2017 | 08:18 PM
  #48
WatsonR's Avatar
WatsonR
But the intercooler inlet is plastic.
Old Feb 19, 2017 | 08:59 PM
  #49
Will Bite's Avatar
Will Bite
I pressured the system today to 20psi using a boost tester a buddy had. Basically it's a PVC cap with an air fitting in it. Couldn't find anything leaking. Makes me think it's a sensor giving a bad reading. I scanned it with all 3 of my scanners got the same codes. Today was the first time I have had my check engine light come on since I've owned the truck. For EGR insufficient flow.
Old Feb 19, 2017 | 09:10 PM
  #50
WatsonR's Avatar
WatsonR
The means the EGR is dirty, if it's still there. If your deleted, then it normally takes a tuner to turn it off.
You could try unplugging the EGR, it will set a code, see it that helps.
Them I'd consider replacing or cleaning the MAP.
Old Feb 19, 2017 | 09:13 PM
  #51
Will Bite's Avatar
Will Bite
The EGR cooler is gone the EGR is plugged in but written out of tune. I've been running stock tune trying to find out my problem. I take it thats why the PCM can't find any flow.
Old Feb 19, 2017 | 09:20 PM
  #52
Will Bite's Avatar
Will Bite
I think after today I'm going to get a new MAP. Is it possible for the MAP numbers to read ok KOEO,at idle, and high idle but still be bad. Maybe just under higher boost. Did you get a chance to look at the log file yet?
Old Feb 20, 2017 | 05:56 AM
  #53
WatsonR's Avatar
WatsonR
That would be correct, soft code for no flow.
The MAP numbers are low.
Old Feb 20, 2017 | 08:26 AM
  #54
Copper.Farm's Avatar
Copper.Farm
Have you installed the new air filter yet?
Old Feb 20, 2017 | 08:28 AM
  #55
Will Bite's Avatar
Will Bite
Yes. No change.
Old Feb 20, 2017 | 09:45 AM
  #56
Copper.Farm
Originally Posted by Will Bite
Yes. No change.
Air filter replaced, connections validates for integrity, that leaves with MAP or MAF.
Old Feb 20, 2017 | 12:30 PM
  #57
Will Bite's Avatar
Will Bite
Ordered MAP today.
Old Feb 20, 2017 | 01:08 PM
  #58
Copper.Farm
Ordered MAP today.
If my memory serves me correctly, that one was a bit expensive.
Old Feb 20, 2017 | 01:10 PM
  #59
Will Bite's Avatar
Will Bite
55 dollars. Thats why I was hoping someone could confirm that it was bad first. Fingers crossed.
Old Feb 20, 2017 | 02:07 PM
  #60
Copper.Farm
wow - my dealer tried to ping me for $120 on the one I ordered and never opened, then returned.
