HELP PLZ
Old Feb 6, 2017 | 03:33 PM
kupiec20's Avatar
kupiec20
HELP PLZ
stuck on the side of road
hit a pothole and truck shut off
tried to restart and nothing
had a spare CPS but no go again
it cranks but no start.
tac not moving while cranking
ty help asap
ty
Old Feb 6, 2017 | 03:42 PM
knottyrope's Avatar
knottyrope
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
see if this chart helps and print a copy of it for glove box for future
Do you have WTS light?
fordman67's Avatar
fordman67
Chip come loose or tin nut come loose?
Old Feb 6, 2017 | 03:51 PM
kupiec20's Avatar
kupiec20
WTS does NOT come on
stock no chip
Old Feb 6, 2017 | 03:54 PM
knottyrope's Avatar
knottyrope
maybe fuel bowl heater shorted out, check fuse 22 under hood
Old Feb 6, 2017 | 04:47 PM
farmert's Avatar
farmert
What Knotty said. If fuse 22 is blown, unplug the fuel heater before replacing.
Old Feb 6, 2017 | 04:48 PM
PSU4ME's Avatar
PSU4ME
Check the connection on the pcm, DS firewall
Old Feb 6, 2017 | 06:29 PM
kupiec20's Avatar
kupiec20
ok i had i towed back home.
fuse 22 is good.
ill have to check the connection tomorrow in the daylight.
so the CPS i tried is used. wonder if that was bad.
something tells me its not the CPS.
any other thoughts?
ty
Old Feb 6, 2017 | 07:44 PM
97-psd's Avatar
97-psd
Did you check the tin nut on the IPR?
Old Feb 6, 2017 | 09:07 PM
redman84's Avatar
redman84
Fuse #9 under the hood.
Old Feb 7, 2017 | 01:36 AM
knottyrope's Avatar
knottyrope
Need the WTS to turn on.
follow the chart I sent and let us know your progress
Old Feb 8, 2017 | 02:42 PM
kupiec20's Avatar
kupiec20
I tried everything....
Now what?
Cranking but no start.
Tach not moving means?
Old Feb 8, 2017 | 02:53 PM
knottyrope's Avatar
knottyrope
Tried what? we cant really tell what you did by "everything"
Tach no moving can be CPS or not cranking fast enough
Does WTS light up now?
Old Feb 8, 2017 | 03:09 PM
kupiec20's Avatar
kupiec20
Ok
Thr truck hit a HUGE pot hole.
Truck instantly shut off.
I tried to restart it. And nothing.
The truck cranks but no start snd no tach.
I changed the CPS with a used CPS.
Truck does not have a chip.
Checked the tun nut.
Fuses 22 and 9 are good
That really all i can tell you
Ty
Old Feb 8, 2017 | 03:40 PM
PSU4ME's Avatar
PSU4ME
Are you sure the "used" cps is functional?
