Big Blue
I will say it would most likely look better, do you really see it, but it should work just as good on that little tilt no?
Dave ----
Dave - It doesn't have to be level. I just don't want to have everything in a bind when the bolts are tightened down. Let's see what I can figure out.
And, as you can see below, the bottom of the receiver is basically parallel to the bottom of the crossmember. But, what you can't tell is that the front lip of the crossmember is 5/8" above the bottom and the rear lip is 3/4"'. So, I see these possibilities for fastening the rear of the receiver:
- Flange: As shown, I could weld a piece of strap to the underside of the crossmember, and then drill it and the receiver and bolt the receiver to the strap. And, since there shouldn't be any up/down stress on that joint, only front/rear, that should be pretty strong.
- Cut: I could cut the bottom off the receiver along the white line that matches the front and rear lips of the crossmember, and then:
- Angle: Weld two pieces of 1 1/2" x 3/16" angle to the top of the crossmember's lips, simulated below with one piece of really light angle, and drill the angle and the receiver so the receiver would be held between the pieces of angle. And cut the bottom 3/4" off the rear 5" of the receiver to clear the crossmember. In addition I'll weld spacers made out of heavy tubing between the walls of the receiver at the rear so the bolts can be cinched down w/o collapsing the receiver. Since the crossmember is 5" front/rear I could easily put two bolts in and it would be quite strong. This would probably be the least obtrusive if the receiver were removed. In fact, the angle could be cut off and the welds on top of the lips ground down such that it wouldn't be obvious they were ever there.
- Weld: Or, I could just weld the receiver to the top of the lips of the crossmember. This wouldn't be as removable as either of the other approaches, but it would be the strongest. And, it could be removed with cutting/grinding such that it wouldn't be obvious.
EDIT: Updated the plan for Angle. I'm liking that plan more the more I think about it.
But, at the moment I'm spending most of my time on Dad's truck. I want to get the front suspension powder coated and back together before September for a car show I'm planning on taking it to.
So, I'm anxious to work on Big Blue and get those things sorted. Especially since there's a long list of things needing fixed with the engine out, like the intake manifold's seal to the block, the pan and dipstick seal, the front and rear mains, the transmission itself, the shim on the driver's side mount, the fuel lines that almost touch the headers, the fuel pressure regulator that will be moved and changed out, the starter and battery cabling that will be replaced, the 3G alternator upgrade, the bolt on the rear of the head that hits the firewall, the oil cooler position and the routing of its lines, the aux battery, etc. But, I need to get Dad's truck on all fours first. Lots to do and so little time.
But, I knew the brace wasn't in the best of conditions as it had set under the battery for decades. So, I put it in the blast cabinet along with the bolts for Dad's truck and cleaned it up a teeny bit. Then I dusted it a bit with semi-gloss black and put it in the oven when the bolts when in. Here are a few before and after shots.
As for what I did today, I made a bracket to hold the outside edge of the coolant recovery reservoir. The original Ford bracket, which I think is E0TZ 17651-A, is no longer available, so I made one. This is what works for me, but isn't all that pretty, although it'll look a bit better with a dusting of powder and 20 minutes at 400 degrees.
But, I still need to find another screw like the one in the front hole. That's the original one that held the front tab of the reservoir to the fender, and it is back in the original hole. So I want to find another to put in the rear hole, which is a new hole in the fender.
