Big Blue
Old Jul 10, 2017 | 08:17 PM
  #1126
Gary Lewis's Avatar
Gary Lewis
I'll have to research the question about different battery trays.
On the radiator support, I can't tell enough about the one in the truck to determine if an earlier one will work or not. There's just too much "stuff" around it. But Jim said he would take pics of his early and late supports to show the differences.
Old Jul 10, 2017 | 08:55 PM
  #1127
fljab's Avatar
fljab
Gary, I've been off the computer all day getting some things done as I've been gone for a week; I'll get the pics first thing in the morning, OK?
FYI, neither of mine are "bare" as they're both installed, but will do my best to show the differences.
Old Jul 10, 2017 | 09:20 PM
  #1128
Gary Lewis's Avatar
Gary Lewis
Jim - I'm not in a huge hurry as I won't be pulling the old one out any time soon. I have to get some things done on Dad's truck, and am just getting Big Blue ready to load and tow Dad's.
Old Jul 10, 2017 | 09:58 PM
  #1129
Gary Lewis's Avatar
Gary Lewis
Jonathan - I put up a new page: Battery Trays - ???Gary's Garagemahal. And there are two different left/driver's side trays - one for the diesel (E3TZ 10732-B) and one for gassers (EOTZ 10732-A). And the diesel's coolant reservoir was very different, so I doubt it would be easy to use the diesel tray in a gas-powered truck. But?
Old Jul 11, 2017 | 12:25 PM
  #1130
Ford F834's Avatar
Ford F834
Good info. Gary, so I guess if one wanted to "upgrade"(?) to a diesel battery tray to be able to accept the taller battery you would also need the diesel type fluid reservoir and washer tank. I'm actually contemplating relocating my driver side battery to accommodate a really good cold air intake and filter, but that's another day and a long way off. The battery tray info may be helpful to me though when I go to configure something
Old Jul 11, 2017 | 01:43 PM
  #1131
Gary Lewis's Avatar
Gary Lewis
Well, I measured the space between the battery tray and the hood's lowest spot. Turns out that there is 9 1/16" of space and the battery is 9 1/2" to the top of the negative post. (Any guesses as to how I measured it?)
A bit of perusing of Odyssey's web site soon discovered that the 31M-PC1500 will fit as it is only 7 7/8" to the top of the negative post. While it is only 850 CCA's vs the 1150 CCA's of the other battery, it is still 200 CCA's above the minimum recommended by the winch manufacturer. So I called 4 Wheel Parts, hat in hand, and explained the situation. Since the battery has never been installed they are taking it back and getting the 31M-PC1500! As I told them, they have my business.
And, Jonathan, I thought about "upgrading" to the diesel battery setup, but I decided that is to much change and the battery may even then not fit. So I'm going with the sure thing.
Old Jul 11, 2017 | 01:56 PM
  #1132
1986F150six's Avatar
1986F150six
[QUOTE=Gary Lewis;17320919]Well, I measured the space between the battery tray and the hood's lowest spot. Turns out that there is 9 1/16" of space and the battery is 9 1/2" to the top of the negative post. (Any guesses as to how I measured it?)
Did it involve placing Big Blue on the lift?
Old Jul 11, 2017 | 02:00 PM
  #1133
Gary Lewis's Avatar
Gary Lewis
No. Hint: What's right ahead of the auxiliary battery? The "shiny" thing with wires to it?
Old Jul 11, 2017 | 02:14 PM
  #1134
1986F150six
You removed the headlight!
Old Jul 11, 2017 | 02:23 PM
  #1135
Gary Lewis's Avatar
Gary Lewis
Yuppers! There's just enough room for me to get my hand through the "bucket" with the headlight out. That let me reach in and make sure the tape was sitting where it should be to get a good reading. It was, and the pic tells the story.
Old Jul 11, 2017 | 02:24 PM
  #1136
1986F150six
What a "bright" fellow, you are!
Old Jul 11, 2017 | 02:25 PM
  #1137
Gary Lewis's Avatar
Gary Lewis
If that's a compliment I thank you.
Old Jul 11, 2017 | 02:28 PM
  #1138
1986F150six
Your dad would smile!
Old Jul 11, 2017 | 02:31 PM
  #1139
Gary Lewis's Avatar
Gary Lewis
Yes, he would. And on that note, Ray Cecil and I've been emailing today. He's really struggling with the loss of his father, so please keep him in your prayers.
Old Jul 12, 2017 | 06:45 AM
  #1140
fljab's Avatar
fljab
I took pictures of both my '81 and '85 and don't see differences on a quick comparison. I was going to upload and will try again, but I've used Photobucket in the past and now they want an annual $399 fee to do it going forward.
I'm somewhat of a techno idiot, so bear with me, but if anyone has a work around, I'll be glad to hear it. Remember to phrase it in a way that someone that grew up with dial telephones will understand.............
