Operator Commanded Regeneration
Old Nov 6, 2016 | 12:26 PM
  #61
carlhwv's Avatar
carlhwv
Originally Posted by Just Strokin
My truck has the compass prior to the exhaust screen
This is my view as well...2016. Still waiting for first regen...only 65% and I'm head out on the road for a 500 mile run tomorrow.
Old Nov 6, 2016 | 01:10 PM
  #62
Just Strokin's Avatar
Just Strokin
Originally Posted by elee3 View Post
So, will it complete the cycle in park? Will it continue if you shift into drive?
Originally Posted by zeroo
FYI, stationary regen is different than normal regen. Your truck is is screaming at 2k rpm's with the fan clutch engaged. Loud. You would not want to shift into drive.
To shift the truck out of Park, you must press the brake pedal. The moment you touch the brake pedal, the Stationary Regen would stop and the engine return to idle before you could move the shift lever.
Old Nov 6, 2016 | 01:15 PM
  #63
zeroo's Avatar
zeroo
That's Correct. Just trying to explain the atmosphere of stationary regen because some people haven't experienced it.
Old Nov 6, 2016 | 01:42 PM
  #64
swarf_rat's Avatar
swarf_rat
And why stationary regen is not very interesting to me. What I want to do is start a regen prior to reaching 100% DFP load, while driving. Start it early in effect. Because I know I will be stopping 20 minutes from now.
Does the CTS let you do that?
Old Nov 6, 2016 | 02:16 PM
  #65
zeroo's Avatar
zeroo
No cts is stationary only.
Old Nov 6, 2016 | 04:17 PM
  #66
L3dford's Avatar
L3dford
Originally Posted by MPD56
Thanks for the reply L3dford:
Please post the feed back. I've been driving around with less then a 1/4 tank of DEF collecting data myself. I was going to set the "ADD DEF" at 200 miles to empty, but still collecting data. About the DSLR, do you know what mileage it was at before it reset? It would make sense if it was below 150? Anyway I have my theory but don't want to jump this thread.
Definitely will. Appreciate yours and others time putting the PID's together. I think you may have nailed it on the under 150 miles causing it to reset.
When I get a min, I'll pull my module info out of forscan and post it. Would be good if we can also get someone that has the ability to do the manual regen to post their info as well for a comparison.
Old Nov 8, 2016 | 09:24 AM
  #67
System's Avatar
System
Prolocutor
So, had to hit Home Depot today and was at 90% when I got there and fully warmed up. Guess what I saw when I put my truck in park? I didn't do a manual regen there as I didn't want to sit in the truck but decided to try it for kicks when I got home. Frank was right. It's LOUD...LOL. Scared my wife inside the house...
Old Nov 8, 2016 | 01:43 PM
  #68
Just Strokin
I think there is something about the 2011 and 2012 trucks that is set or settable that the 2013 and later trucks do not have set...
Old Nov 8, 2016 | 02:07 PM
  #69
Dakster's Avatar
Dakster
Originally Posted by Karl4Cat
Hit him with rep points for this Carl. I did!
I hit him up with reps too. I haven't seen that option, but I admit I was never looking for it. Since at time I am sitting at 90% or greater while idling waiting for my kids to get out of school, if that works on a 2015 it would be nice.
Old Nov 8, 2016 | 02:12 PM
  #70
MPD56's Avatar
MPD56
I just enabled my screen on my 2013 this morning and it shows 60%. If I'm not mistaken the clean option won't show till it is over 85%, is the right?
Old Nov 8, 2016 | 02:13 PM
  #71
L3dford's Avatar
L3dford
Been poking around and found something interesting between a 2012 and 2013.
On a 2012, you won't get the OCR option unless you are 80% full. On a 2013, you won't get the OCR option unless you are 100% full.
This is from the Diesel supplement.
2012 - pg 59
Note: OCR will not be allowed until DPF load percentage has reached at
least 80%.
2013 - pg 37
100% (Full).
I'm going to see if I can get it there and see what happens.
Old Nov 8, 2016 | 02:24 PM
  #72
System's Avatar
System
Prolocutor
That's an interesting find L3. That could very well be the reason guys with 13+ trucks aren't seeing it.
Old Nov 8, 2016 | 04:26 PM
  #73
Dakster's Avatar
Dakster
Mine will say "full" so I will watch it and put it in park and see if I get the option to start a regen on my 2015.
Old Nov 8, 2016 | 05:59 PM
  #74
frankgh's Avatar
frankgh
Been busy but I'm back. Glad to see I don't have a one off! I just got my as built file.
Old Nov 8, 2016 | 06:00 PM
  #75
System's Avatar
System
Prolocutor
There are three of us so far Frank. All with 2012's. If L3ford is right, the 13-16's may be next...
