Leveling kit
Old Sep 12, 2016 | 09:50 PM
  #61
LEDman's Avatar
LEDman
Originally Posted by Rutcutter
ByersFarm he was thinking I still thought the 17's still run leaf springs up front.. Lol
I'll snap some pics tomorrow before I go get the tires put on,still tempted to go 37's but I think I should stay with 35's for Towing the Toy Hauler.
Yes the 350's need a leveling kit if your not gonna tow 24/7 IMOP due to the rake.
My experience is that once you've gone to 35s, 37s aren't a noticeable difference on these trucks (as far as power). They will only be a few more pounds and the radius isn't that much more. But they look better if they fill up the wheel wells.
Old Sep 12, 2016 | 10:08 PM
  #62
ByersFarm's Avatar
ByersFarm
My avatar is our 08 that's a leveled 350 on 37/13/17 boggers. I ran 37's on my 09 for a bit. It's just too dang tall to work out of the bed with 37's. They look great though.
Old Sep 12, 2016 | 10:22 PM
  #63
AtlM5's Avatar
AtlM5
Hell, my truck came from the factory with 34 inch tall tires. I know for a fact you can fit 37s without touching the suspension, but it would look much better with a leveling kit of some sort.
Old Sep 12, 2016 | 10:30 PM
  #64
EpicCowlick's Avatar
EpicCowlick
The alignment shop will have the information on the bushings. I forget the name of the manufacturer but it's a name you'd recognize. You might want to call ahead and make sure they have them ready for you. It will save an hour or two while their parts truck zooms to another shop.
Old Sep 12, 2016 | 11:53 PM
  #65
Blk04Snake's Avatar
Blk04Snake
Originally Posted by Ricohman
You won't be using shims on a coil spring truck. Shims are for leaf sprung trucks.
You need bushings and longer lower arms to put it back to factory specs. You axle has also been pushed rearward as well as off to the side.
With caster half the factory spec any play in your front end will make the wheels wobble like an old shopping cart.
Negative. Look at the upper ball joint. It has an eccentric in there and they are made in many different degree settings. You just have to remove the OEM one that is there and replace with one that will add the caster back in. I had a BDS 2" level in my 2010 F350 that came with these eccentrics called "Ball Joint Alignment Cams"
Old Sep 13, 2016 | 05:31 AM
  #66
Skipdaddie's Avatar
Skipdaddie
Originally Posted by EpicCowlick
Good point. Ford would have to provide either a different track bar or a different (lower) track bar bracket. Which raises this point: If the front end is two inches higher with the snow plow package, which part numbers are different? Track bar or bracket? HOLY SMOKES! Ford may already make a leveling bracket! Who has the parts book?
Has it been confirmed that the plow package trucks sit higher? If so, I need to revise my build and ad the plow package.
Old Sep 13, 2016 | 06:54 AM
  #67
Rasalas's Avatar
Rasalas
If you read the spring specifications all front springs at varying weights are the same length. If the plow package sits higher (without the plow) it would be due to the front springs not being compressed as far due to their higher rating (6000 lbs) compared to the standard springs which rise in 400 lb increments from 3800 lbs. The 4x2 springs are designed at 12.2 inches at design load and the 4x4 springs at 14.7 inches (F-250 - F-450). Since vehicle design is at rated weight and deflection I would imagine the components are set and designed for the operating rate and any difference in height would be due to stiffer components rather than purposeful height difference.
See page 14 of the specifications for the deflection rates of the front springs.
https://www.fleet.ford.com/truckbbas...kups_PRINT.PDF
Old Sep 13, 2016 | 07:31 AM
  #68
EpicCowlick
We're still waiting to hear if the bar or bracket is different for a snow plow prepped truck. The bottom line is if the snow plow prepped truck sits 2.5 inches higher when unladen, Ford has either accommodated that via a change to bar or bracket or they simply accept the variance and consider the steering geometry correct when the snow plow is attached or not. We're just waiting for confirmation of part numbers to see if the bars or brackets are different. That will tell a lot.
Old Sep 13, 2016 | 08:32 AM
  #69
dh1200's Avatar
dh1200
Im pretty sure they sit higher. Ive never measured them, but every one ive seen, looks higher with a bigger wheel well gap. Dont know if its a full 2.5 inches taller but their definitely higher.
Old Sep 13, 2016 | 09:01 AM
  #70
jlalanas's Avatar
jlalanas
I'd be willing to bet you're right on this for the same reason the aftermarket leveling kits/installers say that an adjustable track bar or different track bar bracket isn't necessary for a leveling kit. Regardless of the factory spring chosen, they all probably sit within a tolerance that is acceptable to Ford.
Old Sep 13, 2016 | 09:14 AM
  #71
EpicCowlick
And that will be good to know. If Ford is effectively saying that a 2.5 inch level is still within acceptable margins (by virtue of the taller snow plow springs), then a simple bracket will be plenty adequate. We've been wondering about adjustable track bars with which you could make micro adjustments. It's starting to sound like anything within 2 inches of OEM track bar bracket position is ok.
So the manufacturers of the two inch spring spacers are correct when they say track bar re-positioning is not needed. But they're probably just barely correct. Anything more than 2 inches would actually be outside acceptable tolerances.
Old Sep 13, 2016 | 10:10 AM
  #72
jlalanas's Avatar
jlalanas
So the manufacturers of the two inch spring spacers are correct when they say track bar re-positioning is not needed. But they're probably just barely correct. Anything more than 2 inches would actually be outside acceptable tolerances.[/QUOTE]
I agree with you, probably not necessary but knowing it's off would bother me enough to get the relocator bracket or the adjustable track bar.
Old Sep 13, 2016 | 01:14 PM
  #73
Katymike's Avatar
Katymike
Trailering
One factor I am considering is the total height my truck will be after I install the 2.5" kit and 35" or 37" tires. Will it still go through my local automatic car wash???? With the additional cab height, it may be an issue. It sure is nice to be able to drive it through on Friday afternoon instead of going home and spending an hour or so cleaning it......
Old Sep 13, 2016 | 01:51 PM
  #74
dh1200's Avatar
dh1200
So are you guys saying that a snow plow truck has a more stressful angle on the ball joints just like a level has been known to do? I always thought that they accounted for this, but now that i think about it, since the plow package is only $85, so i doubt that includes different joints and what not. Im sure it would still be in tolerance, but just not as good as one without the package. I dont know, im just guessing.
Old Sep 13, 2016 | 02:31 PM
  #75
jlalanas's Avatar
jlalanas
I think you may be thinking of this as is relates to a truck with IFS, in which case yes a level kit puts more stress on the ball joints because it changes the angle...happened to me on my 04 F150.
Although a level kit on a solid axle, control arm suspension does change your caster angle, I"m not sure that it necessarily puts more stress on the ball joints, but I guess it's possible.
