Leveling kit
Old Sep 5, 2016 | 05:54 PM
finchturf's Avatar
finchturf
Leveling kit
Any on the market yet that use springs - not spacers? I had an Icon on my '12. New truck is here - now it needs upgrades!!! Will the adaptive steering be an issue if I level it?
Old Sep 5, 2016 | 06:46 PM
Rutcutter's Avatar
Rutcutter
I'm fixing to level mine out also and wondering the same thing myself.
Old Sep 6, 2016 | 06:39 AM
Xwild's Avatar
Xwild
The other thing to think about if your leveling is the lane keeping warning, and adaptive cruise. You'll be changing their respective angles to the ground.
Old Sep 6, 2016 | 07:40 AM
Rasty1's Avatar
Rasty1
Sounds like you should talk to a Ford tech before adding a leveling kit.
Old Sep 6, 2016 | 07:58 AM
Rasalas's Avatar
Rasalas
That is a legitimate question but one would think that unless adding a drastic rake the systems should be built to operate correctly with a load which would in essence level the ride. I guess of greater concern would be the systems functionality after adding leveling and then adding payload which would aim everything much higher than intended as in the coon hunting effect. I am still inclined to believe the angle of divergence in the camera and sensors is adequate to compensate for the change. Besides, what happens to the lane departure warning when you spin the rear view around to pick the kale out of your teeth from your breakfast shake?
Old Sep 6, 2016 | 10:19 AM
Katymike's Avatar
Katymike
Trailering
Anyone know where I can get a leveling kit for the 2017 F350?
Old Sep 6, 2016 | 05:34 PM
LEDman's Avatar
LEDman
Some guys on FB are saying the 2016 Rough Country work on the 17s.
Old Sep 6, 2016 | 05:39 PM
EpicCowlick's Avatar
EpicCowlick
"Work" is the operative word. Is it just a spring spacer or does it also include a drag link re-positioning bracket and caster adjustment bushings? Any leveling kit should have those things at a minimum.
Old Sep 7, 2016 | 12:35 PM
17F250's Avatar
17F250
Fabtech has a 2 inch leveling kit out. FTL 5208 is their 2 inch kit. Also 4 wheel parts has either the poly or the metal 2.5 inch kit available. The metal one is $50 more. Shipped it was a little under $200. Havent got it in yet but called the national 4 wheel parts number after seeing nothing on their site for the 17's and they had them in stock and shipped me one.
Old Sep 7, 2016 | 12:40 PM
Rutcutter's Avatar
Rutcutter
Not sure which way i'm going to go on the leveling kit,I just talked to the guys over at Carli suspension and the tech said that adj drag link isn't really required for just a 2" as its kinda in the "gray area".
Now I need to find the alignment specs for the 17 before go in as I know the shop doesn't have the info for the 17's yet.
Old Sep 7, 2016 | 12:47 PM
EpicCowlick
If the drag link is not re-positioned or extended, the entire axle will shift about 1/2 inch to the driver side. I agree that it's kind of gray area as almost no one would notice without looking for it. Still, I want to do it just so there's no tension in the system anywhere. That one half inch shift will put pressure on the control arms even if just a little bit.
And what about caster bushings? MediumDan said that would be the other important component to change.
On my 2011, I did the spacer and the bushings but still had issues with wobble. This time I will do those but also a new drag link bracket.
Old Sep 7, 2016 | 12:50 PM
Rasalas's Avatar
Rasalas
I would think it extremely important to visit a good frame and alignment shop for a full 4 wheel alignment after modifying the suspension. The cost of tires and the nuisance of ill handling are too great to not ensure that everything is exactly correct.
Old Sep 7, 2016 | 12:54 PM
EpicCowlick
Absolutely. Swapping caster bushings necessitates an alignment. Finding a "Good" shop, well, that's the trick.
Old Sep 7, 2016 | 12:56 PM
Rutcutter's Avatar
Rutcutter
Epic have you found a drag link bracket that your gonna use yet?
Old Sep 7, 2016 | 01:01 PM
EpicCowlick
This one seems to be about the best quality. I just don't know if it fits the new 2017 frame. I put a call in but haven't heard back.
2008-16 4WD Ford F250, F350 Super Duty Track Bar bracket 2"-2.5" lift - Ford - Track Bar - Suspension Parts
