Looking under carb there is no reason why it should go only to one. It looks evenly coated both ways on the bottom of the carb, but it is there so at least some of that sludge is coming from the PCV. What is causing that and is it just because it sat without driving for a long time?
Piston rings could get stuck from sitting, but I doubt that's the case here.
I *think* you're seeing some staining from the PCV and a larger amount of oil leak from one or two ports being shared by the other cylinders on that side of the plenum.
I didn't remove the intake or have a firsthand opportunity to examine any of the sealing surfaces.
That some areas of the intake gaskets pulled away cleanly from the heads is somewhat telling.
Did some one say manifold leak try this and you will know were every leak is letting air out or fluids in the manifold.there is a post up near the top of the page this tool will locate any leak for you in minutes.
... and you used the proper torque sequence -in steps- to reach final torque?
I mean, it's not as critical as a head gasket, but it is best practices.
I did. It had the correct sequence on the instructions (which I actually read! I do not read instructions often and when I do I get leaks so I may want to stay away from that like usual) that came with the manifold.
hharris8 my best guess would be just as you said the pvc but more then likely it came from the time when it was running and could be from weak rings or bad valve guide seals.The pvc does suck vacume from the valve cover,s and would leave a deposit of greasy gook after a while how many miles were on the engine.You know hharris8 just take some carb cleaner spray and let both sides have it and bet most of that sludge will be gone or less noticeable.
Thanks for your help. I will check those things. I am currently not interested in purchasing the "ultimate leak detector", but will notify you if I become interested.
That's ok It was just a hobby for me I had a vacume leak in the evap system and took months to track it down the dealer wanted like $400.00 and they were going to pull the tank after I found a broken vent valve and I told them to forget it then I built the leak detector to help find my problem and it turned out to be a pin hole in the line from the charcole canister to the vent valve after putting in dye because smoke wasn't showing up any were it took like five minutes to locate the pin hole and I do mean pin as in so tiny that you couldn't see smoke coming out of the hole and you couldn't see it with your eye until dye was added to the oil and then it dyed the location of the leak.And it was only visible under ultraviolet light.
