More brake issues
Old Jul 15, 2016 | 06:56 AM
  #61
ultraranger's Avatar
ultraranger
Originally Posted by 70FE250
Seem to have found my excessive brake pedal travel issue. Damn passenger side brakes are just trash on this truck
At least now you know what's causing the problems.
Old Jul 15, 2016 | 11:19 AM
  #62
Stangman96gt's Avatar
Stangman96gt
I noticed that you have the ebrake on in that picture. I suppose the shoes would be pretty mangled if that side isn't releasing the ebrake for some reason, but if you just have them on then nvm what I said hehe.
Old Jul 15, 2016 | 04:57 PM
  #63
70FE250's Avatar
70FE250
Ebrake was on since the opposite wheel was on the ground, gotta stay safe
Old Jul 16, 2016 | 10:22 PM
  #64
70FE250's Avatar
70FE250
All right guys one more question, I made the mistake of not noting which side my adjusters go on so they keep going out of adjustment, anyone know of the appropriate line up for the adjuster for front and rear shoe? 12x2.5 drums
Old Jul 17, 2016 | 01:40 AM
  #65
GaryKip's Avatar
GaryKip
" To prevent incorrect installation, the socket end of each adjuster is stamped with an R or L to indicate their installation on the right or left-side of the vehicle. The adjusting pivot nuts can be distinguished by the number of lines machined around the body of the nut. Two lines indicate a right handed nut; one line indicates a left-handed nut." From the 69 Chilton manual.
Old Jul 17, 2016 | 06:06 AM
  #66
Tedster9's Avatar
Tedster9
Well that'll do it...
Once you start removing and installing the brake components, you'll start to understand the star adjusters. If you are facing the brakes, like in the picture, the star wheel must turn "down" to expand the shoes out into the drum. If you're accessing from the backing plate side, the star wheel always has to be turned "up". Always.
To tighten the shoes only a single tool is needed. Loosening the star adjusters, the lever needs to be pushed out of the way simultaneous to backing off the wheel. The idea of course, is that the brakes will not loosen up on their own. Note too, the self-adjusting feature needs a fairly close initial, manual adjustment of the shoes into the drums. If this is not done initially, no amount of backing up will adjust the brakes. Ever. This is a common error, if the shoes are not adjusted correctly into the drum "light drag"; the pedal will be low and mushy. Old, oversize drums will not adjust correctly. A good brake job "back in the day" involved arcing the shoes on a machine to fit the drums perfectly. This is no longer done, consequently braking action and pedal "feel" won't be what it should be right away. More adjustments will be needed to reach a good pedal height. A proper brake job will put your passenger through the windshield.
Old Jul 17, 2016 | 01:48 PM
  #67
70FE250's Avatar
70FE250
How messed up my truck would be without you guys.
You guys a lots of help thanks
darkgoku
Oct 18, 2011 10:02 AM
andrewk
Mar 25, 2008 03:22 PM
rmalottwtes30
Sep 23, 2007 01:09 AM
Colo_Steve
Aug 30, 2004 05:00 PM
beerlizard
Bronco II
Oct 21, 2002 01:17 PM
