What manual works with my '70 since they don't seem to have a "official" one for this year? And man, pulling the entire axle shaft to take off the drum is just... wow. Gotta wait for payday tomorrow to purchase new rear drums/hardware
FREEZE! You don't have to take the rear axle(s) out to get to the brakes. You only need to back the star wheel off enough for the drum to slide off the axle.
Note to question your knowledge, but you sure? I have the dana 60 full float axle. It doesn't seem to come off without taking it off
Ah, scratch that --I tend to think in relative terms. I have an F100. F100s don't require unbolting axles and such --just back the brake adjuster off, remove the drum and bah-da-boom, there's the shoes and hardware right in front of you.
I wish it was that easy. But this isn't really that hard, just a nuisance to me
I'm no stranger to drum brakes but it's also because of that that I much prefer discs. They are far easier to service and you don't have out of adjustment issues with them that you do with drums.
Presently, my '69 F100 has (power) discs front/drums rear. My truck had manual 4-wheel drums when I bought it 5 years ago. I have most of the major components to put discs on the rear --I just need a pair of 31-spline axles with a 4.5" lug pattern and have the front rotors machined and redrill the lug pattern from the current 5 x 5.5" lug pattern to a 5 x 4.5" lug pattern, a new set of 5 x 4.5" lug pattern wheels and I'll have power 4-wheel discs. --but, that's a conversion that's down the list to do at a later date.
I'm wondering if the person who turned your drums measured them. There is a maximum diameter spec and both drums on an axle should be the same size. Lots of people turning drums don't know either one of those facts.
As far as I know, the drums are original and so are the rear pads
There's a thread on here that I'd love to do for rear disk brakes but that's more than necessary for now. No dak has no donor trucks to use for the swap
Since I don't have an F250/F350, and I've never worked on the brakes for either one of those, I don't know exactly what's needed for the rear disc conversion --the front calipers/rotors and the caliper anchor brackets?
2) Rotors (1975 -1988 GM 3/4 ton 4x4 truck front)
• (2) Calipers (1975 -1988 GM 3/4 ton 4x4 truck front)
• (1) Set of brake pads (1975 -1988 GM 3/4 ton 4x4 truck front)
• (2) Soft brake lines (braided stainless steel lines available)
• (2) Banjo bolts
Copied off a website selling the kit. Not bad but not really necessary since towing won't be happening much
• (2) Banjo bolts
WAIT! I just finished fine tuning my brakes today, on my 69 F250. I had to lift both rear tires off the ground and turn quite a while with a brake tool until the brakes just started to drag. I did the fronts and then after filling the repaired radiator, I slowly backed out of the driveway. I backed down the street and did about a dozen short stops to help adjust the brakes. I should have adjusted the brakes more while I had it jacked up. After a trip around the block I parked it with the E-brake on. The brake warning light came on. I backed it down the street a while longer, hitting the brakes, and the light went off and now the brakes work very good. Take the rubber plug out and use a flashlight to make sure the wheel is turning the shaft in the right direction.
