Georgia Chapter Join Chapter, Leader: OPEN SPONSORED BY:
March Chat Thread
Old Mar 26, 2016 | 06:50 AM
  #151
ChiefM's Avatar
ChiefM
Getting my caffeine fix and then fixing to hit it hard and heavy.
They already told me I was going to have some real good stuff so I had to have a driver.
Old Mar 26, 2016 | 06:52 AM
  #152
hturner12's Avatar
hturner12
The take home drugs will be the weak ones. They will dope you good for the surgery.
Old Mar 26, 2016 | 07:21 PM
  #153
ChiefM's Avatar
ChiefM
The new pinion seal is in, I also fixed some loose exhaust and had to repair some wood that goes along the bottom and holds in the access doors. The new wood really stiffened things up and the doors are working great again. Took me a ton longer than I expected especially since I had to fix the wood and didn't get to the awning or the aux generator. Good thing is neither one are show stoppers. Just glad it is done and mobile again before the rain comes tomorrow. I am beat and realized I am not a spring chicken anymore.
Old Mar 26, 2016 | 07:34 PM
  #154
hturner12's Avatar
hturner12
What brand ginny?
Old Mar 27, 2016 | 07:53 AM
  #155
ChiefM's Avatar
ChiefM
Onan emerald,
I think there is an issue with the fuel pump and I am sure the carb needs either cleaning or rebuilt after not working for years now. 3 years ago I got it to fire off for a second on starting fluid so the engine itself is good, or was.
Going to try and pull the awning roller tube off today if the rain holds off for a while and see if I can figure out what is going on with the springs. I would like to get the awning fixed before we go on our trip as the Florida summer sun can be killer.
Old Mar 27, 2016 | 08:21 AM
  #156
hturner12's Avatar
hturner12
The Onan pump is high dollar. You can buy an aftermarket pump and make it work.
Old Mar 27, 2016 | 08:52 AM
  #157
ChiefM's Avatar
ChiefM
Going to check voltage to it, PO seemed to think there was a problem with the board. I was thinking of grafting in a 12v cr pump if thats the only problem, saw it on the classic winnebago site.
Thunder, lightning and misting right now so it looks like an inside day.
Old Mar 27, 2016 | 10:08 PM
  #158
hturner12's Avatar
hturner12
Make sure you are sitting down when you check prices for ginny parts.
Old Mar 28, 2016 | 10:45 AM
  #159
axelgawn's Avatar
axelgawn
Hey is that yard in Griffin a cash only yard or do they take card. I might be up for a trip this weekend?
Old Mar 28, 2016 | 12:39 PM
  #160
hturner12's Avatar
hturner12
They take cards but you may get a better deal with cash
Old Mar 28, 2016 | 04:37 PM
  #161
Philthy50's Avatar
Philthy50
Hey everybody, sorry I have been away, work has kept me busy these past few weeks. But, hopefully, I will get some work in on the 50 here soon. I was planning on soft mounting in my 85 Jag front suspension, but now am leaning towards hard mounting(welding it in). It will get me an inch or two lower in the front. Hope all is well with everyone.
Phillip
Old Mar 28, 2016 | 06:16 PM
  #162
ChiefM's Avatar
ChiefM
Took the motorhome into town today and got the front end aligned. It drove like a dream on the way home till the transmission took a dump on me. Only good thing is I was only a block from home and my neighbor pulled me up the driveway to the house. Unfreaking believable, guess it's better that it went out today than on the way to the beach. Guess we are now going to just get a room as I am not going to try to be in a big rush to to fix it.
Good news is the pinion seal I just put in doesn't leak.
Old Mar 28, 2016 | 08:30 PM
  #163
hturner12's Avatar
hturner12
What chassis is under it?
Well I feel *******. Went to start the truck today No Oil Pressure on either gauge but truck sounded ok. Did a post in the IDI forum about it. The suggestion was to pulthe sender check for oil. Pulled the turbo feed had oil, pulled the sender had oil, disconnected the line had oil. That when I found the problem that I created last week and did not realize it. When pulling the vacuum lines out I pulled two wires out of the connectors I thought both were for glow plugs. Actually one was oil pressure sending unit wire. Problem found on electrical gauge. Now on to the mechancal side. Disconnected both end of tube could not blow thru it. Found the problem was created last week when I was taping up some excess wiring for the boost /egt. I ended up putting a kink in the line. Untaped everything rerouted line good oil pressure again
Old Mar 28, 2016 | 08:57 PM
  #164
Big_Texxan's Avatar
Big_Texxan
[QUOTE=axelgawn;16153670]
Originally Posted by Big_Texxan
i love gear oil. sarcasm.
Safe travels man
dropped the knuckles off to have the king pin bushings reamed out for the king pins. Found me a good machine shop, good ole southern boys, know their ****. Dirty shop, but impressive stuff.[/QUOTE
Do you know if that shop does anything with drive shafts? I know with a new transmission I will need to shorten my two piece driveshaft and possible put a different yoke on it. I wish I knew how to fab stuff for my build. This outsourcing is getting pricy :/
I will ask next time im in there. They are a pretty nice size machine shop
Old Mar 28, 2016 | 08:58 PM
  #165
Big_Texxan's Avatar
Big_Texxan
Hope yall had a good easter. Met the girlfriends rest of the family.
I also got a lead on a 1991 420sel Benz, while I was there. Cousins hate it, it just sits. Might buy it, fix it, drive it, sell it.
