CAN BUS
Old Oct 16, 2022 | 08:29 PM
  #46
Kbs117's Avatar
Kbs117
Originally Posted by mrwrench
does the 2005 f250 4x4 have CAN -BUS ?
sorry, protocol voltages are not affected by the oil tempature sensor being plugged in.
Old Oct 16, 2022 | 09:15 PM
  #47
Kbs117's Avatar
Kbs117
That's my question, I guess, is the oil temperature sensor on the protocol system on this truck? And would a shorted to ground sensor affect protocol voltages?
Old Oct 17, 2022 | 06:07 AM
  #48
bismic's Avatar
bismic
Couple of things -
The EOT sensor is on a 5V reference circuit. Shorting out this circuit (sensor, connector, or wiring harness) can impact PCM operation. EOT is used for numerous things:
If the oil temperature sensor indicates (even falsely) that the engine is over 131 *F, the glow plugs will not come on.
In the '03 engine "Inferred EBP Strategy". EOT is somehow used in the process to estimate/infer the EBP value.
EOT is also used by the FICM in its fueling calculations.
So - bottom line .................
With the EOT sensor shorted out, the glow plugs and fuel system will be getting the wrong information from the computers causing: poor operation, or even a no start can occur (glow plugs and/or low computer reference voltage) and white smoke (excess fuel) situation. Pretty uncommon for a no-start though.
You should have stored codes if you have a good code reader (ie ForScan). You should also be able to retrieve PCM data for v-reference voltage.
Ryan50hrl
All Things Towing
13
Dec 17, 2008 09:59 PM
PetesPonies
Sep 1, 2008 12:25 PM
FlameOut
1983 - 2012 Ranger & B-Series
Jul 17, 2007 06:31 PM
bmp887
Sep 18, 2005 05:05 PM
Jekylltamer
Mar 30, 2005 08:14 PM
