CAN BUS
Old Feb 2, 2016 | 06:29 PM
mrwrench's Avatar
mrwrench
CAN BUS
does the 2005 f250 4x4 have CAN -BUS ?
Old Feb 2, 2016 | 07:57 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Yup, it does. I think I got my terminology right to say the architecture is a Controller Area Network and it uses the CAN protocol for most of the data traffic on the bus, however its not exclusive. There are other protocols on the bus and a select few of the PID's can only be found by connecting with those.
Old Feb 3, 2016 | 11:56 AM
mrwrench's Avatar
mrwrench
do u know if I can connect a ford navigation that need canbus signal?
Old Feb 3, 2016 | 06:05 PM
cheezit's Avatar
cheezit
There is a high speed can, low speed can and a acp network.
Most audio stuff runs the acp. However im not sure about the navi and wich of the 3 it runs on.
So far as will it plug and play thats a loaded question. I belive some were coded to the vin there is also a question of what harness is in the dash.
Old Feb 4, 2016 | 06:50 PM
mrwrench's Avatar
mrwrench
I installed a navigation from 09 Mountanier (Pioneer) and it works - now I would like to install the new version (Clarion) and it only show me a white screen for few seconds -
I call to Navrepair and he said that the new model need can bus signal to turn on . and they said the 05 doesn't have can bus .
how to know ?
Old Feb 4, 2016 | 06:57 PM
cheezit's Avatar
cheezit
The evtm will tell you.
Your truck does have hs can, just not for audio that runs on the acp network.
Old Feb 5, 2016 | 02:44 AM
Yahiko's Avatar
Yahiko
There is not any CAN buss to the head unit in the 05 from what I can see by
looking at the diagram. The one thing you get is VSS and the analog control
switches on the steering wheel.
I'll attach the Diagrams in PDF format for you.
Old Feb 5, 2016 | 04:59 AM
Rusty Axlerod
Hey Sean, can you tell if the steering wheel controls were still analog in 2006? I bought a nice bluetooth phone interface but haven't installed it yet because it says on vehicles with can bus controls on the steering wheel an extra adapter is needed.
Old Feb 5, 2016 | 01:25 PM
Yahiko's Avatar
Yahiko
06~07 still analog.
I put in a aftermarket head unit and had to get the little
box so that the wheel controls would work.
I put the 06~07 PDF up for you.
Have a look at page 130-3 in the PDF.
Old Feb 5, 2016 | 03:59 PM
Rusty Axlerod
Thanks Buddy! The install instructions for my device says it works with analog steering wheel controls, may "learn" some CAN bus vehicles (my truck wasn't on the list) and the additional adapter was required for the rest. I have the PIE adapter in there now for audio input so I should be good to go,,when I get my truck running correctly again.
Thanks for the print also, I wasn't looking foreward to getting back into those discs you sent and figuring out how to display the prints. The text and graphics for repairs work fine but whatever viewer the prints come up in wouldn't work for me.
My apologies to the OP for the
Old Feb 5, 2016 | 11:41 PM
Yahiko's Avatar
Yahiko
You know that so long at I have a tiny bit of time I can do it for
anyone that asks. The funny thing is the later ver of the manuals
is easier to pull the PDFs from. The 03~04 I have to build them
one page at a time.
Old Feb 22, 2016 | 06:24 PM
mrwrench's Avatar
mrwrench
can I get bus signal from the cluster?
Old Feb 22, 2016 | 08:41 PM
Yahiko's Avatar
Yahiko
Look in post #17 at the PDF for (14-1 Module Communications Network)
If it on the main network there you can pick it up anywhere that network goes.
So yes you can get CAN Bus at the cluster. But keep in mind that you have to
terminate it correctly or your going to have problems. Correct termination can
be a problem without knowing the needed permitters and what is already in the system.
Old Mar 3, 2018 | 08:15 PM
mrwrench's Avatar
mrwrench
cab bus
ab bus
what is the ACP nwtwork?
thanks
Old Mar 3, 2018 | 09:08 PM
Yahiko's Avatar
Yahiko
Check this info out on Automotive networks.
https://en.wikipedia.org/wiki/Vehicle_bus
