First Excursion Second Owner
Old Jan 30, 2018 | 12:24 AM
  #241
seijirou's Avatar
seijirou
Front row out of a newer superduty with the jump seat, put it in the 2nd row. Really should be about the same difference with cutting/welding the seat frames to bolt in vs. your existing newer 2nd row setup. You might even be able to bolt the seats to those frames you already modified without too much difficulty.
EDIT: Something like this.
https://www.ebay.com/itm/1999-2016-F...-/112745396032
Old Jan 31, 2018 | 06:38 PM
  #242
5HUB's Avatar
5HUB
Decided not to do the dash and am now moving in a different direction with build, selling all the interior and starting over. I’ll try to get info from guy buying my dash to see about a write up to post. Going into a custom shortbed single cab Super Duty.
Old Feb 12, 2018 | 01:24 PM
  #243
unleashd's Avatar
unleashd
Originally Posted by 5HUB
Swapped the tan for the black, the tweeter pods snapped right in, will have to wire in when I do speaker Upgrade. I'll have to paint door lock.
Were the window controls and door locks etc. a direct plug in?
I am picking up a set of door panels later this week and wondering if I have to do more wiring than necessary to get the mirror controls for the power fold & telescope.
Old Feb 12, 2018 | 02:30 PM
  #244
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
NO they are not, Prakash. You will have to convert all the plugs. I did a write up on it.
Old Feb 12, 2018 | 02:42 PM
  #245
unleashd's Avatar
unleashd
Thought they were straight swaps and bought the door panels. Guess, I have more electrical work to do. Let me go and search for that post.
EDIT: Found that thread - https://www.ford-trucks.com/forums/1...l#post17406565
Old Feb 23, 2018 | 01:07 PM
  #246
5HUB's Avatar
5HUB
Decided to go with Expedition middle row seat and eliminate 3rd row. Blank slate back there.
Old Feb 23, 2018 | 06:59 PM
  #247
fordboy2's Avatar
fordboy2
So is the project back on? Decide against the shortened superduty?
Old Feb 23, 2018 | 07:47 PM
  #248
5HUB's Avatar
5HUB
Sorry, meant the dash was going into a shortened Super Duty, not me.
Old Feb 23, 2018 | 10:06 PM
  #249
fordboy2's Avatar
fordboy2
I see, maybe I miss understood. Still would love to see a write up on it.
Old Feb 23, 2018 | 10:14 PM
  #250
Orlando1976's Avatar
Orlando1976
Found a local guy that does it, couple days ago. Because the Excursion is my DD, I just purchased a Land Cruiser to drive and flip, while truck is torn down. Kinda at a stand still right now. Going to take advantage and strip out complete interior for updating and insulating. Also putting on 2017 SD mirrors that have been on the shelf for a while.
There is another guy who almost has newer guage cluster completely figured out to swap, so kinda waiting on him as well. Newer Steering column is last thing.
The guy that was going to do the dash was he going to make the navigation system work? Any info on the cluster guy
Old Feb 23, 2018 | 10:21 PM
  #251
5HUB's Avatar
5HUB
Not sure what his plan is for the dash, I asked him to show me the finished product. I might go with a 2010 Dash instead. Check out: Zachary @e4motors on instagram for guages.
He is only doing 7.3 swaps at the moment.
Old Feb 25, 2018 | 07:02 AM
  #252
fordboy2's Avatar
fordboy2
Front seats bolt right in, wiring harness has to be spliced in.
Had to add a switch for cooling feature. Didn't use seat warmers because no way to regulate heat, stayed constantly on and was getting hotter and hotter. I have the Super Duty Carpet put away, was planning on using eventually. Looks like it may fit right up to 3rd row hump, probably use a cargo mat of some sort where carpet ends.
What type of switch did you use for the cooled seats? I scored some seats out of a 2012 yesterday and will be putting them in later this spring. I'll want to use the heat function also though, did you ever get that to work or decide you did not care since your in Texas?
Old Feb 25, 2018 | 07:11 AM
  #253
fordboy2's Avatar
fordboy2
Also did you have to custom build the brackets for the expedition seats to mount in or how did you go about it?
Old Feb 25, 2018 | 03:31 PM
  #254
5HUB's Avatar
5HUB
Old Feb 25, 2018 | 05:47 PM
  #255
fordboy2's Avatar
fordboy2
That switch is for the cooled seats not the heat correct?
