So my selector switch on my hub ( plastic) broke. I can't find on line a replacement piece? I believe there the original waren hubs. Time for new ones? Any suggestions and help.
Does this mean that I can take a set of manual hubs from some random Ford truck with 50/60 axle(I know the 44s have smaller hubs) and replace my mom's 02 F350 vacuum hubs with them?
It looks like you can do that swap with aftermarket hubs easily enough... but stock JY hubs seem a lot cheaper.
Is it an actual Warn branded hub, or re-badged with FORD? If it's Warn branded, it should have a lifetime warranty. Last time we had one crack, we called the local 4x4 shop, they didn't even ask for a receipt, just swapped it out. Only downside is, they would only swap the whole pair of hubs, not just the cap, so I had to pull both.
