General Discussion Thread
Old Dec 31, 2017 | 09:55 AM
  #556
fordguy2100's Avatar
fordguy2100
Originally Posted by JessyJ
Had a huge ice rain last night, it,s just below freezing. I hear thousands are without power. My power was out for about 8 hours which was bad enough.
Oh wow! Ice storms are no joke. We got a couple more inches of snow last night. Probably up to about 4 or 5
Old Dec 31, 2017 | 10:06 AM
  #557
JessyJ's Avatar
JessyJ
Never seen anything like that storm before here in BC, usally we get 10feet of rain but not of the freezing kind. Hope my hedge survives.
Old Jan 1, 2018 | 08:17 AM
  #558
SlikWillie's Avatar
SlikWillie
We had a bad ice storm in Oklahoma back in Dec 2000. We were without power for 3 weeks and no water for almost 2 weeks. People go into survival mode real quick. Portable generators come up stolen everywhere. Even the small solar panels from railroad crossings went missing. Good luck you all over you going through that up there.
Old Jan 1, 2018 | 04:49 PM
  #559
Keymaster's Avatar
Keymaster
Speaking of cold, what is everyone doing for heat in their garages? It looks like this cold snap is for real this winter and I haven't bothered to install heat in my garage since building it 15 years ago. At my old house, which we bought from my father-in-law, he had a simple 55 gallon drum that he used in the garage. You can buy the kits online for fairly cheap. I already have someone that can give me the drum for free. I kept about 12 feet of insulated stove pipe from my old house that I can use, so I hope I can get this guy installed in a week or so.
https://www.homedepot.com/p/US-Stove...0aAu2KEALw_wcB
Chris
Old Jan 1, 2018 | 05:30 PM
  #560
privateer, eh's Avatar
privateer, eh
I've got a pair of old non recertifiable propane saddle tanks from an old 88 f450 and am going to cut 1 in half and weld it back together into a stove. Will be putting an end wall on it for feeding, cleaning doors and a stoking vent, will be devising some sort of heat exchanger system so that I can run ducting in the garage and get heat through out. Its a bit of work but I want to start putting in some serious shop time now that I have a decent place to work out of. This garage used to have a gas stove and still has the chimney, I'll be burning wood as its free for me.
Old Jan 1, 2018 | 05:39 PM
  #561
Keymaster's Avatar
Keymaster
Wow, ducting, huh? Must be one heck of a garage! Mine is 30x26. At my old house, once you got the fire good and hot, it would run you out of there and this was in a garage with no sheet rock, just bare studs. Wood is a lot of work, so I'll probably just have some delivered. Folks around here can get a pickup truck of seasoned oak delivered from around 75 to 100 bucks.
Old Jan 1, 2018 | 05:58 PM
  #562
privateer, eh
We've got the better part of 7 months of winter and I'm semi retired with a few projects that I'm behind on. This garage is 24 x 28 and has potential as it was set up properly at 1 time but that was years ago. The electrical needs to be checked out and probably upgraded as this place was built in the 50's but the electrical panel is a lot newer. Theres a 220 feed but its not hooked up and I need a dedicated line that'll handle my lincoln welder that can draw up to 40 amps on a 110 line. Theres a lot of work that needs to be done on this place but it'll be worth it as I'll be able to work from home from now on.
Old Jan 1, 2018 | 06:03 PM
  #563
Keymaster's Avatar
Keymaster
Ah, I just noticed you live in Calgary, so heat is paramount for you up there. I had a 220 feed ran for my garage in case I ever wanted to learn how to weld. Still haven't delved into it yet, but I would love to try it. My dad's 77 needs a new rear fender on the driver's side and one of the cab corners needs replacing too. Good luck on the garage, it's really nice to have the work space you need.
Old Jan 1, 2018 | 06:12 PM
  #564
SlikWillie's Avatar
SlikWillie
Well, I just have a single car garage. I have a space heater set on low, so none of my liquids freeze up, stays around 40-45 degrees. When I want to play in there, I fire up a second space heater. They sit in the middle of the floor so nothing gets hot and sparks up.
Old Jan 1, 2018 | 06:15 PM
  #565
privateer, eh
The 220 feed will be for an 80 gallon compressor and in the future I'll be looking into a Tig set up. I'll be going a bit overboard on the heating as I need to prevent freeze up or I may be needing to stock up on compressors, its not nice to freeze your compressor on a regular basis. lol
Old Jan 1, 2018 | 07:30 PM
  #566
Jklnhyd's Avatar
Jklnhyd
We used to have a pellet stove in our garage as a kid. That thing would make you need to open some doors if you got it going. My dad had a cabinet shop and put one in there. He liked them so much and customers asked about it, he started selling them.
Old Jan 1, 2018 | 07:58 PM
  #567
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I had a wood stove in my shop, it took to long to heat up and used too up to much clearance space. So I use to run a older style small forced air kerosene, it finally gave up the ghost.
So I went and got a new style Dewalt DXH135HD thermostatically controlled forced air kerosene heater burns at 135,000 BTU/HR and can be used with kerosene diesel, fuel oil or JP-8 fuels. It will be T shirt work temp in the shop in about 10 min.
Old Jan 1, 2018 | 08:37 PM
  #568
Keymaster's Avatar
Keymaster
Hmmm, Amazon has those for around $300. Now you got me thinking.....
Old Jan 1, 2018 | 11:03 PM
  #569
77&79F250's Avatar
77&79F250
I got my new one from Meeks lumber yard when my old one quit on me on a real cold day. I was under the gun to get heat back in the shop. My old little one was ok, if you run kerosene in it. Pump diesel and it was a smelly beast after a while.
This new one is bigger, more BTU and WAY quieter (that matters when in the shop with it). And I only use kerosene in it, have no smell issues. 14 gal tank, fuel gauge, thermostat, put together in 1 min.
Mr. Heater Dewalt 135,000 BTU Forced Air Kerosene Construction Heater | L & M Fleet Supply
Military discount, no sales tax (since it is for farm use) and I could not say no.
Old Jan 2, 2018 | 05:53 AM
  #570
1978f-250's Avatar
1978f-250
Chris
My garage is about 20'x 55 1/2' but where the cars park (2 1/2 car) is separated with a wall from the rest. I have 2 propane heaters and 3 100lb. tanks. If I do a lot of work out there in this brutal cold the 3 tanks will last most of the winter. If it's not brutal cold then I only need 1 heater on.
Dennis
