Pump Timing
Old Sep 4, 2015 | 11:21 PM
The_Josh_Bear's Avatar
The_Josh_Bear
Pump Timing
Right, but that's assuming they didn't get one with a re-manned IP. My 89 didn't have one stock and my reman has one, for example.
Old Sep 5, 2015 | 10:38 PM
84&04's Avatar
84&04
So I did the lift pump
Took out the lift pump... It was weak and nasty, and started to leak -_- oil is ok thankfully.
Still no luck... It went from a decent amount of coal to gray -_-
As for a torque screw, I'm entirely lost, I was referring to the one behind the cover. Pictures of torque screw?
Old Sep 5, 2015 | 11:33 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Originally Posted by The_Josh_Bear
You're talking about the fuel screw inside the IP, under the triangular plate on the side, right? "Towards the radiator" makes me think you're adjusting the "torque screw" or whatever it's actually called, which is on the outside of the pump.
Thats the impression i was under.
Old Sep 5, 2015 | 11:38 PM
84&04's Avatar
84&04
Eh
The "fuel screw" being horizontal and all, when twisting it you'd be effectively rotating the Allen towards the radiator.
Old Sep 5, 2015 | 11:46 PM
hairyboxnoogle
Half the time... if the "handle" of the allen were pointing down, you would be turning it toward the cab. "IN" is clockwise, aka right handed thread.
Old Sep 6, 2015 | 12:00 AM
Macrobb's Avatar
Macrobb
If you can get an allen in there such that it's pointing down... I'll ask you what you did with your valley pan.
Old Sep 6, 2015 | 12:03 AM
hairyboxnoogle
I did it when i had the pump of and sitting in the vice lol. I was simply saying so theoretically. That said, things are alot clearer when using terms like clockwise / counter clockwise, in / out, vs. toward the radiator, especially when the screw is parralell to the axle, the screw would turn in towards the drivers / left side if anything.
Old Sep 6, 2015 | 12:28 AM
The_Josh_Bear
Pump Timing
Hahaha
axel 56
Jun 14, 2011 09:34 PM
trooperkelly
Jul 20, 2007 11:52 AM
edroe
Jan 14, 2006 08:31 AM
dux
May 25, 2004 07:13 PM
alantbird
Jan 1, 2001 09:58 AM
