Pump Timing
Old Sep 2, 2015 | 08:10 PM
84&04's Avatar
84&04
Pump Timing
Turned the pump up 4 flats, had no smoke while loaded, decided to try to gain a bit of power. Had nothing. Went up 2 more flats, all I have is gray brown black smoke, replaced fuel filter, common issue? Still gray, but now even less since the fuel filter... (Not looking for coal, but the girlfriends truck has higher miles, still puts a bit of black out)
113k rebuilt
Injection pump (13k)
Injectors (13k)
No noticeable oil or coolant loss
Compression 340-350
Lift pump (13k)
Always starts within 5-10 seconds of cranking with no glow plugs.
Lack of thermostat wouldn't cause the gray smoke would it?
I'm assuming pump timing... (No access to timing light currently, should I tilt pump?)
Old Sep 3, 2015 | 08:18 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Thermostat could because it doesnt warm up. Put one in, you will either wipe the cylinders or overheat it. The fact that you got 6 flats out of it tells me something is weird, never got much more than 3 out of one. Sounds like a wore out pump. Timing wont cause lack of smoke, but should be in the neighborhood of 6-9ish BTDC via pulse adapter.
Old Sep 3, 2015 | 08:20 PM
84&04's Avatar
84&04
I was always assuming they backed it out for economy? I backed it out 2 flats and put it back in pretty sure it was only 3 flats just felt like more lmAo. I'm almost positive it'll go more
Old Sep 3, 2015 | 08:21 PM
Macrobb's Avatar
Macrobb
Honestly, with an old pump like this? adjust it a bit and see what feels the best. You won't be able to time it correctly with a light, because the timing curve will be off.
Just get it where it feels the best/has most power and call it good, while saving up for a new performance pump(chances are your pump is a crummy rebuild?)
Old Sep 3, 2015 | 10:18 PM
hairyboxnoogle
Were you going in or out?
Old Sep 3, 2015 | 11:28 PM
84&04's Avatar
84&04
Originally Posted by Macrobb
Honestly, with an old pump like this? adjust it a bit and see what feels the best. You won't be able to time it correctly with a light, because the timing curve will be off. Just get it where it feels the best/has most power and call it good, while saving up for a new performance pump(chances are your pump is a crummy rebuild?)
it was supposedly replaced about 11k ago from the local IH dealer. The PO painted it so it's hard to tell what's what.
towards the radiator
Old Sep 4, 2015 | 01:48 AM
hairyboxnoogle
no, were you turning the fuel adjustment screw in or out?
Old Sep 4, 2015 | 05:33 PM
dropitlow88's Avatar
dropitlow88
toward the radiator would be in is my assumption.
Old Sep 4, 2015 | 06:27 PM
bashby's Avatar
bashby
Clockwise is in
counter clockwise is out
Old Sep 4, 2015 | 06:30 PM
84&04's Avatar
84&04
Hmmmmm.... So why did the smoke increase? Or are my truck and I just that retarded. Hahahaha
Old Sep 4, 2015 | 06:33 PM
84&04's Avatar
84&04
According to what I just read, clockwise is more fuel?
Old Sep 4, 2015 | 07:09 PM
Macrobb's Avatar
Macrobb
Yes, you did it right. You should mess with the timing at this point to gain anything more out of it.
Old Sep 4, 2015 | 07:11 PM
84&04's Avatar
84&04
I guess I'm gunna have too lol.
But sadly it's going to have to wait. It's birthday celebrating time tonight! Thanks for your help guys! Especially you Macrobb! You've no idea how much easier you've made this!
Old Sep 4, 2015 | 07:33 PM
The_Josh_Bear's Avatar
The_Josh_Bear
Pump Timing
You're talking about the fuel screw inside the IP, under the triangular plate on the side, right? "Towards the radiator" makes me think you're adjusting the "torque screw" or whatever it's actually called, which is on the outside of the pump.
Old Sep 4, 2015 | 10:37 PM
Macrobb's Avatar
Macrobb
Older trucks/pumps(Not sure the exact year, but it was after 88) didn't have a "torque screw". There's no real reason for the screw anyway except emissions, maby.
