Sponsored by: Auxito
Pulls Right Which Isn't Right
Old Sep 14, 2015 | 09:34 PM
  #61
steve(ill)'s Avatar
steve(ill)
YEP........... you cant win them all........... but you do seem to be on a loosing streak lately ! Hopefully that will change SOON !
Old Sep 14, 2015 | 11:21 PM
  #62
FordTruckChuck's Avatar
FordTruckChuck
LOL. Thanks.
More questions on the way...I think I'll start a new thread for them.
Old Sep 24, 2015 | 03:02 AM
  #63
FordTruckChuck
I suppose it should be common sense but I just realized that I had better get a look at the rear brakes while I'm at it. I hope the rear drums come off easier than the rotors did. Although isn't it usually the other way around?
How safe is a truck on nothing but jack stands?
Old Nov 13, 2015 | 03:29 AM
  #64
FordTruckChuck
Unhappy Ugg...
Well...after replacing rotors, calipers, pads, brake drum hardware, R/F steering knuckle, upper control arm, lower ball joint, getting an alignment & moving tires around, it still pulls to the right. This really sucks.
Old Nov 13, 2015 | 01:51 PM
  #65
pdqford's Avatar
pdqford
Just wondering if they did a "Thrust" alignment. That's where they determine where each rear wheel is pointed and then align the front wheels parallel to the rears.
Old Nov 13, 2015 | 02:04 PM
  #66
Bluegrass 7's Avatar
Bluegrass 7
Just ad-libing a little, using common sense,
Both wheel have to travel in a straight line but account for minor technicalities such as TOW in, Camber etc.
If a brake drags on one wheel it changes the situation.
If a wheel bearing has an issue it changes the situation.
If something is loose it changes.
If the suspension has an issue it changes.
If the frame is bent or rusted through and weak it changes.
Road crowning can pull a perfect alignment.
A Tire can be the source.
A tight or wavy disc from over tightening can cause tracking problems.
A caliper putting to much pressure on one disc will cause a pull.
Mixed pad sources can cause different coefficients of friction side to side.
A faulty hose with an internal break to the outer covering will cause uneven braking.
Anti lock brake fault to one stde can be a cause.
Someone doing the work and on the alignment rack has to see something and on a test drive.
There is never a problem without a real answer if it's looked for in earnest.
Sometimes we get caught up into thinking there is only one problem when there is more than one, at the same time.
Hope you get it solved.
Good luck.
Old Nov 13, 2015 | 04:29 PM
  #67
FordTruckChuck
Arrow
Maybe it's the current phase of the moon.
lol.jk.
Thanks for the input.
Old Nov 13, 2015 | 04:37 PM
  #68
FordTruckChuck
Hmm...I'll have to see if the printout they gave me mentions that.
fordguy55
Jul 21, 2017 06:57 AM
KILLER'S_60&66
Apr 3, 2008 05:54 PM
boxcar1974
Mar 28, 2007 01:12 PM
hardknox00001
Nov 10, 2006 01:45 PM
cahook
May 19, 2004 12:08 AM
