Sponsored by: Auxito
need help with overheating
Old Nov 9, 2015 | 09:43 PM
eeron's Avatar
eeron
98 5.4L v8 and the obo stopped @359999 after i bought it and put a new engine in her,but i need help my truck is blowing white smoke out of the vents. i have been told could be the heater core, radiator line ... not sure.can anyone help me with this?
Old Nov 9, 2015 | 10:04 PM
Bluegrass 7's Avatar
Bluegrass 7
Only way it get out of the vents is the heater core.
Good luck.
Old Nov 10, 2015 | 03:28 AM
FordTruckChuck's Avatar
FordTruckChuck
What does it smell like?
Old Nov 10, 2015 | 08:11 PM
steve(ill)'s Avatar
steve(ill)
For short term, you can cut and splice the heater hoses together under the hood and take the heater core out of the loop. Truck will still run, but no heat in the cab. ....... if you loosing coolant, it should have a sweet smell, and will leave a residue on the windshield when in defrost mode.
Old Nov 10, 2015 | 08:13 PM
steve(ill)'s Avatar
steve(ill)
Check to see that your loosing coolant from the overflow tank.......... no possibility you dumped something inside the duct when changing out the motor ?
Old Nov 13, 2015 | 08:01 PM
toby tough's Avatar
toby tough
Blowing smoke? Sounds like maybe the blower motor is going bad on you. A guy I used to work with years ago had his catch fire and burned half the dash up. If it's the heater core do something soon. The stuff will make your headliner deteriorate and start falling down.
WVFordTruckMan
1997 - 2003 F150
Feb 16, 2011 12:28 PM
grip1968
Mar 8, 2010 06:17 PM
brentleedragon
Oct 8, 2006 11:38 AM
funkoptimus
32
Feb 13, 2005 12:29 PM
frankle
1978 - 1996 Big Bronco
Feb 25, 2004 06:53 PM
