Lets see those 5th wheels
Old Jan 23, 2016 | 12:22 AM
  #421
8ball1974's Avatar
8ball1974
out to the keys. Had a question; what's a reasonable amount of clearance between the bed rails and the fifth wheel?
I did this twice. My bad.
Old Jan 23, 2016 | 12:40 AM
  #422
Jigger2020's Avatar
Jigger2020
I would say 4'' is plenty, try & get the trailer to sit level.....
looks like a great spot to camp, welcome to FTE
Old Jan 23, 2016 | 04:30 AM
  #423
scraprat's Avatar
scraprat
Top Answer: 5
I thought it was at least 6" but more is better if you can get the trailer level. At 4" I would be watching some of the dips that are at the approaches to some places.
Old Jan 23, 2016 | 06:57 AM
  #424
Jigger2020's Avatar
Jigger2020
I see his truck is jacked up so if he can see 4'' then ....
Old Jan 23, 2016 | 07:02 AM
  #425
BeaverCrap's Avatar
BeaverCrap
Is this Key West KOA?? Nice rig! I also have that turkey fryer...lol
Old Jan 23, 2016 | 07:53 AM
  #426
senix's Avatar
senix
4-6" is what I would expect for clearances
Old Jan 23, 2016 | 11:58 AM
  #427
8ball1974's Avatar
8ball1974
Thanks for the info guys. I notice there is 3 settings on the hitch itself. It's in the middle setting I think if I bring it down it will be about 2 inches at the most. I will have to measure the clearance first though while it's turned to make sure the neck clears the rails too now that I think about it. Guess that's what I get for want a 6' lift; pic was at Boyd's camp ground in key west.
Old Jan 23, 2016 | 02:31 PM
  #428
Irelands child's Avatar
Irelands child
You can probably get away with 4" with a short bed truck while I sure wouldn't want less then 6" with a long bed, especially if the 5er doesn't have the extended pin box. Or, of course, by staying on a nice smooth road and low approach hills 4" will work on the long bed.
Old Jan 23, 2016 | 03:13 PM
  #429
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I have been told 5-7" for the height between bed and trailer. Nice motorcycle also! I used to have a 2003 GSX-R Alstare until someone turned left in front of me and ended the life of the bike. I then bought a 2008 Hayabusa which was a lot of fun for a few years.
Old Feb 2, 2016 | 02:48 AM
  #430
02F250V10's Avatar
02F250V10
I have somewhere between 8-10 inches on mine and I've been pretty close to touching a few times. I tend to camp off the beaten path though. Here's a pic of our rig. Not as nice as some but it gets the job done.
Old Feb 2, 2016 | 06:20 AM
  #431
superrangerman2002's Avatar
superrangerman2002
Nice!
I like it right sized for camping off the beaten path and short enough to pull a small boat as well!
Old Feb 2, 2016 | 09:14 AM
  #432
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Your rig looks great !!
We take ours off road at times.......smaller would be nicer at times......
This is May 2015........Willow Creek Reservoir, outside Augusta Montana.
Old Feb 12, 2016 | 08:55 PM
  #433
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Starting to make improvements to the Montana ...........
The 50A Power Line is a heavy hunk of copper........
Instead of coiling it up and getting a fork lift to put it in the storage compartment..........
A Reel to make the job easy........
Old Feb 13, 2016 | 05:52 AM
  #434
Jigger2020's Avatar
Jigger2020
nice, I've seen those reels in electric 12v too Roy
your trailer is dirty
Old Feb 13, 2016 | 06:01 AM
  #435
Irelands child
Roy - that is a nice add on. I've looked at the reels as well but since I seldom use the 50 amp wire (only have one a/c until later this year) just leave ours coiled in the 5er's basement and use the short or long 30 amp cable with an adapter.
