'03 F350 High Pressure Fuel Pump Replacement
Hello, this is my first time posting on here, I have 3 questions and please excuse my ignorance. I am not a mechanic and have limited knowledge of diesel engine maintenance.
1.) Is it really necessary to pull the cab off my '03 F350 to replace the High Pressure Fuel Pump? My local Ford dealership want $3150 for the job.
2.) Is $3150 about right for this kind of job or is that high?
The truck is 12 years old, has 140,000 miles and the rear wheel wells and body under the rear doors are showing rust pretty badly thanks to the salt used in our CT winters. I've made other repairs in the past year to the tune of $2500 for an oil leak, fuel leak and misc other "minor" ailments.
3.)Is this vehicle even worth spending that kind of money on at this point?
For one thing spend a litle time looking thru the tech folder. Lots of good info and tests you can use and how to run them,the values you should see and values you shouldn't see.
Invest in something that can read live data and pull codes. You will need this to help diagnose and work on your truck. There are a lot of optios available. Full scan tools; monitors;smart phone apps designed for diagnoseing your truck.
To WatsonR, Thanks for the response, the dealer said "High Pressure Fuel Pump" and I only know its bad because the truck stopped running. I had the check engine light come on, checked it with a code reader and it was "P2290 Injector Control Pressure Low" made an appointment to bring the truck in for service but then lost power on the highway pushing the gas pedal the engine was revving and I was going slower and slower until I got to a safe spot to pull off the road and shut it down. It would not restart after that and it seemed no fuel was going through.
Our trucks do not have a high pressure fuel pump.
If you choose not to get a gauge reading system like the scangaugeII, then you will be at the mercy of believing what you are told. As Watson said, it could end up costing you more money than you need to spend.
The cab does not have to be removed for the high pressure oil pump (which is what actuates the injectors and causes fuel to be injected). It should not cost $3150. It is a common issue with the 03 and early 04 model year, but with a scangaugeII, you can get some information that may confirm the diagnosis.
The fuel is pressurized to around 55psi by the fuel pump and regulated by a spring near the fuel bowl. The high pressure oil pump is pressurized to around 3000psi (maybe more) and controls the injectors to open/close them (injector control pressure). If ICP is lower than 500, truck won't start. Unpluged, it's forced it to use 500, still won't start, means the HPOP isn't making enough pressure to run.
Could be an leak in the system or the pump itself. That is a lot of work to get to it, top of the motor comes off except heads. If you decide to have it done, get a better HPOP, I think Bullet Proof Diesel makes a billet unit that is superior to the OEM pump. Have them install that instead of OEM. I'd also consider an oil cooler since your already there, OEM on that one for sure.... after a chemical flush of the cooling system... do not skip the flush if you do a cooler.
Truck bed new is $2500, used even cheaper and these motor have been known to run well into the 300K range if taken good care of, even more!
tough call... sell my truck for scrap prices or fix it for $4000 and drive until it falls apart... buy a new truck and take the chance of having to do the work anyway.
My dealer telling me that's it's a fuel pump issue and knowing it's really the high pressure oil pump may make me rethink who I take it to.
Good luck
Randy
Good luck
Randy
anthonym92
05-31-2017 05:38 PM
JerryHooper
6.4L Power Stroke Diesel
05-19-2011 07:21 AM
