Need help wont start
Old Mar 13, 2015 | 11:14 PM
  #61
Nitrodude's Avatar
Nitrodude
Originally Posted by HD Rider
Then I would not trust the scangauge. Get a bluetooth adapter and TorquePro app for a smart phone and try that, or get a hydraulic pressure gauge and plumb it into one of the heads.
I have an elm bluetooth dongle somewhere-ill dig it out.
That will read icp with the free torque app?
Or do I need to buy the real torque app?
Old Mar 13, 2015 | 11:23 PM
  #62
HD Rider's Avatar
HD Rider
That's a question for Tugly.
Rich! Are you watching this one?
Old Mar 14, 2015 | 06:44 AM
  #63
Pitcrw6's Avatar
Pitcrw6
Nitrodude, where you located in Florida?
Old Mar 14, 2015 | 11:00 AM
  #64
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Free version will read ICP. Cost is less than a Big Mac so full pro version is easily worth it.
Old Mar 14, 2015 | 03:20 PM
  #65
Tugly's Avatar
Tugly
HD Rider invited me to the party under the guise of answering Torque questions.
This sounds to me like you might get this bad boy running for the price of 8 sets of injector O-rings from Riffraff diesel. No ICP, fuel bleeding everywhere, lots of smoke, hydrolocking - you have an injector really loose or some bad O-rings. Do the Cody test to be sure.
Any foreign fluids in the coolant?
Torque Pro is worth it, if your device connects to the OBDII/BT adaptor.
Old Mar 21, 2015 | 11:29 AM
  #66
Nitrodude's Avatar
Nitrodude
Sorry I Havnt gotten back to you guys!
I had someone come look at the truck and try to scan it-he said the truck won't communicate with the computer-something electrical is wrong with it.
Tried cranking it and it wouldn't fire-he used ether and it ran for a couple seconds off it and died.
His verdict was its not getting fuel/injectors arnt firing.
I have fuel coming into the fuel bowl up front (can drain the bowl-turn the key on and it refills the bowl)
Again-this is 5ish year old diesel! So I'm sure its lost some potency.
Coolant looks clean.
And I'm in south florida area-port chrlotte.
Old Mar 21, 2015 | 11:34 AM
  #67
HD Rider's Avatar
HD Rider
Does the wait to start light come on.
Old Mar 21, 2015 | 11:36 AM
  #68
Nitrodude's Avatar
Nitrodude
Yes wait to start light comes on-truck beeps and light goes out
And I can hear te fuel pump when the lights on.
Old Mar 21, 2015 | 11:54 AM
  #69
HD Rider's Avatar
HD Rider
Check all the fuses. Don't forget the ones under the hood. I believe the diagnostic port is powered from the cig lighter fuse. The WTS light indicates the PCM is getting power.
If all the fuses are good, try swapping the PCM from another truck.
Old Mar 21, 2015 | 12:08 PM
  #70
Nitrodude's Avatar
Nitrodude
Ill check the fuses. Pretty sure I checked what I think was the cig lighter fuse and it was good but ill double check it/just replace it anyways.
Unfortunately I don't know anyone with another 7.3 to swap parts with
So I'm stuck with having to seriously troubleshoot and replace if I have to.
Old Mar 21, 2015 | 03:40 PM
  #71
coax9952's Avatar
coax9952
What kind of scanner did your friend use to check it....some times it takes several tries to get them to chat, and rearrangment of protoccols etc.
Old Mar 21, 2015 | 05:30 PM
  #72
Nitrodude's Avatar
Nitrodude
Not sure what it was called. He has an adapter to a toughbook laptop and tried two different softwares that I guess he uses on 7.3's all he time and it works.
But it wouldn't connect to my truck-which makes sense because my scangauge didn't seem to work with my truck even though it would "connect" it wouldn't read anything but volts.
TheDieselChick
19
Jun 30, 2018 04:29 PM
cwbright
May 30, 2016 01:47 PM
JamesHajek
74
Jan 29, 2012 06:43 PM
FSJ-EARL
Jul 15, 2011 02:36 PM
cojab
Jul 31, 2008 10:35 PM
