Duallys Only
Old Sep 16, 2015 | 08:35 AM
  #991
Big-Foot's Avatar
Big-Foot
Maybe I got lucky with mine as I have no leaks...
Good thing though as I could not figure out how to get the fitting to release the line...
Old Sep 16, 2015 | 10:01 AM
  #992
golfmedik's Avatar
golfmedik
I take a small enough open ended wrench to go around the line and push down on the connector firmly and pull the air line out.
Old Sep 16, 2015 | 10:50 AM
  #993
Big-Foot's Avatar
Big-Foot
Seems simple enough... I did try that and it didn't release. Maybe I didn't push hard enough.. Well, since I don't have any leaks now, I'll just leave things alone... LOL..
Thanks!
Old Sep 16, 2015 | 11:16 AM
  #994
sdetweil's Avatar
sdetweil
Thanks!
I usually have to push in on the hose at the same time pressing on the retaining ring..
Old Sep 16, 2015 | 11:49 AM
  #995
Big-Foot's Avatar
Big-Foot
Ahhhh... I did not do that... Good to know!
Old Sep 16, 2015 | 04:30 PM
  #996
CarlT100's Avatar
CarlT100
Scott, beautiful pics and a very nice rig.
Old Sep 18, 2015 | 09:49 PM
  #997
cay5628's Avatar
cay5628
Originally Posted by IronCobra
Hi everyone, my names Justin and I've been a dually owner for 5 days.
Nice truck Justin. Congratulations and welcome to the best forum, "Duallys Only"
-Mark
Old Sep 20, 2015 | 01:38 PM
  #998
Jesse4812's Avatar
Jesse4812
Hauled my '56 White to a truck, tractor and engine show yesterday. Effortless towing.
Old Sep 20, 2015 | 01:42 PM
  #999
sdetweil's Avatar
sdetweil
Nice!... both of them!
Old Sep 20, 2015 | 03:43 PM
  #1000
Big-Foot's Avatar
Big-Foot
X2!!!!!!
Old Sep 20, 2015 | 05:22 PM
  #1001
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Was White trucks made in Lansing, Mi.?
Old Sep 20, 2015 | 05:44 PM
  #1002
Jesse4812's Avatar
Jesse4812
Whites were made in Cleveland, Ohio. I believe Reo trucks were made in Lansing, Michigan.
Old Sep 20, 2015 | 05:48 PM
  #1003
bigredtruckmi
Veteran: Navy
I knew the REO was but was not certain on the White
Old Oct 6, 2015 | 03:58 PM
  #1004
cay5628's Avatar
cay5628
Greeting Dually Fans,
Cindy and I just took our first long distance trip with our new Dually and fifth wheeler, from San Luis Obispo, Cali area to Corpus Christi, Texas. One way so far and I have some observations. We went out I40 then south from Amarillo to the coastal bend.
1. The truck pulls Our 15,400 pound trailer with little effort. The 2015 power rating makes it quite fun to drive. Quite an improvement over the heavily modified (bulletproof and tuned) 6.0 we traded in. Going up and over several mountain ranges along the way, this tuck easily pulled the grades rarely shifting back a gear while maintaining the speed limit (75 mph). Gotta love the speed limit, everywhere but California. The manually selectable engine brake worked very well both on the grades and when hauling the combination to a stop. In combination with the tow/haul trans I believe a well thought out setup. The only issue along the way as was the trailer tires. The Goodyear/Marathon tires made in China are not up to sustained speeds above 65 and one let loose in downtown Alberquerque NM on the Interstate at the posted speed limit (65). We got it pulled over to the side, alas there was way too little space and mush to dangerous conditions to change on the roadside, so we slowly pulled about 1/2 mile to an exit and found a place in a commercial building parking lot and changed the tire. We put 4 new LT 235/85R16E commercial tires on in Tucumcari NM (thanks Quality Tire and Lube).
2. Towing with a Dually platform vs single rear wheel platform. IMHO it was far more stable, less wander. Generally we felt safer. I'm not castigating the SRW trucks, just giving our feelings having experienced both. We'll never go back as long as we are towing heavy.
3. We were due for an oil change once we arrived at our destination. Have used Sames in Corpus Christi before and they did their usual great job. Oil and fuel filters this time (16,400 miles). I switched to full synthetic oil on my first oil change (Chevron). The Ford dealer used Royal Purple, I was a bit surprised as I expected Motorcraft had a full synthetic oil for the diesels. I didn't ask and am not worried, Royal Purple is good stuff as far as I know. Also got the dealer to check the coolant additive, which checked ok and they killed the "Check Coolant Additive" light.
Overall we are quite happy with our new Dually and its capabilities.
-Mark
Old Oct 6, 2015 | 04:10 PM
  #1005
BIGTRUCKBIGRV's Avatar
BIGTRUCKBIGRV
-Mark
Welcome to my stomping grounds! I live in Corpus. What brought you here specifically? Are you staying on the island or Rockport?
