No ICPV
Old Nov 13, 2014 | 09:40 PM
IHateCommieCars's Avatar
IHateCommieCars
No ICPV
Scangauge says my truck has no ICPV and I'm thinking that might be why it won't start. How do I fix that?
Old Nov 13, 2014 | 09:51 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Disconnect the ICP sensor and try to restart
Josh
Old Nov 13, 2014 | 09:57 PM
Yahiko's Avatar
Yahiko
One diagram coming up.
Sean
Old Nov 13, 2014 | 10:15 PM
IHateCommieCars
It still doesn't start, so I guess that's not my main problem, but how to I fix this one anyway?
I saw the diagram Sean provided, but that electrical diagrams are all Greek to me.
Old Nov 13, 2014 | 10:17 PM
Bullitt390's Avatar
Bullitt390
You have several threads going?
Do a run down:
Updated STC?
Updated dummy plugs?
Air check?
Recently replaced injectors or oil cooler?
IPR screen intact?
Josh
Old Nov 13, 2014 | 10:18 PM
IHateCommieCars
Sean
Thanks for helping. I feel stupid because I don't understand electrical diagrams. What could cause me to lose ICP voltage? Is it a part that can be replaced? A pigtail? The ICP sensor? Or what?
Old Nov 13, 2014 | 10:50 PM
IHateCommieCars
Do a run down:
Updated STC?
Air check?
IPR screen intact?
Josh
Yes, I did post multiple threads. Sorry, guess I am a bit impatient - need to get this truck running.
I haven't replaced the STC - not even sure it hasn't been replaced already. Is there any way to tell it's bad without tearing into the engine? Or, for that matter, how would I tell if I have an oil leak at all? I have good ICP and IPR readiings while crankiing (although ICP is 0 at KOEO, it does go over 1200 when cranking).
I haven't done the air check yet. It was cold here today and I'll be working on this outside. Also, just not sure I have any symptoms that indicate an oil leak.
I'm waiting on my IPR socket to arrive in the mail. It is 14.8 KOEO and goes to around 50 will cranking. However, it stays just above 30 at idle. Would that suggest there is nothing wrong with the IPR?
Old Nov 13, 2014 | 10:54 PM
r2millers's Avatar
r2millers
Don't fell too bad about reading wiring diagrams. Trying to keep up with 12 pages and many, many points of electrical contact makes for difficult reading for most of us.
What does your scan gauge show as IPR psi as a %? Should show more then 15% but not exceeding 85%.
If your IPR is trying to increase psi from the ICP sensor readings, you probably have a HPOP associated leak somewhere.
Remember, you still need about 540 psi minimum to start.
Old Nov 13, 2014 | 10:58 PM
Bullitt390's Avatar
Bullitt390
What are the ICP Volts when you see 1200 psi?
Josh
Old Nov 14, 2014 | 01:57 AM
Yahiko's Avatar
Yahiko
Sometimes people get freaked out about wiring diagrams
not sure how you feel other than lost reading one.
One simple way to think of one is just like a road map.
The sensor is the house your going to. Some have more than
one route to get there and there is always a way back home.
We will call the battery home. Sometimes you have to make a
stop on the way to or from home to the place you going (PCM).
I know it can be a little intimidating but start slow. Print out a page
and use a color marker to mark the path you need to deal with and
ignore the rest.
One page 6 top left just under the 6.0L Diesel you can see the IPR.
It is connected to "C" and that is 12Vdc battery it goes down the
line to the PCM. The PCM controls the ground by switching it off and on.
When it on or grounded then the valve is getting power and bringing
the pressure up. Now what you need to know is this. at C1360 do you
have +12CD on pin A? If yes then we need to see if the PCM is switching
or not.
I found you something easy to watch and not burry you.
Sean
EDIT : I wanted to also add this PDF that has the symbols for you.
http://www.autoshop101.com/forms/toyOH_3.pdf
Old Nov 14, 2014 | 08:21 AM
IHateCommieCars
Originally Posted by r2millers
What does your scan gauge show as IPR psi as a %? Should show more then 15% but not exceeding 85%. .
It's around 50%. I'm assuming from watching DTRon's vids that if IPR was trying to increase ICP it would be 85%.
Old Nov 14, 2014 | 08:27 AM
IHateCommieCars
Josh
I never get any ICPVs KOEO or when cranking. Makes me wonder about ScanGauge actually. Where did you get those Xcommand settings? Why doesn't ScanGauge list that command on their site?
I guess I need to buy a voltmeter and figure out how to use it to confirm. I notice in Bismic's No-Start troubleshooting list in the tech folder that I should check the ICP sensor circuit fuse, but don't see that one in the fuse box diagram.
Old Nov 14, 2014 | 08:53 AM
IHateCommieCars
Sean
Wow, great info. My problem begins with having very little understanding of how electricity works. Then, I didn't understand what all the symbols mean - you've helped with that.
I think you're telling me to check that the IPR is getting power from the PCM to raise the ICP pressure. But, I'm getting ICP pressure NOW according to SG - about 1200psi - not sure why SG only showed 300 right after the truck died. It shows 1200+ every time now.
The only SG numbers that don't seem just right - from what I know - is IPR at idle being in the low 30s and the ICPV reading at 0.00 KOEO and cranking, if the Xcommand settings for ICPV I was given are accurate. I assume I have fuel pressure since I just replaced the pump and blue spring and can see the secondary bowl filling up fast. And I assume I have low oil pressure from watching the dash gauge register and seeing the oil filter bowl fill up fast when cranking.
How can I tell if I have high oil pressure or a leak? I understand that the air test will tell me where to look for the leak, but I was hoping to confirm that I have one before going to the effort to rig up the air test (gotta get adapters).
My first thought was IPR valve, but now I wonder since SG doesn't show IPR being a problem during cranking. If not that, then I guess it is a high pressure leak somewhere. I'm also concerned with ICPV, but since the truck doesn't start with the ICP disconnected, wouldn't it rule that out?
Old Nov 14, 2014 | 08:55 AM
IHateCommieCars
Is there a list somewhere of additional Xcommand settings over and above the ones listed for Ford on the SG site?
Old Nov 14, 2014 | 09:04 AM
Money-Pit's Avatar
Money-Pit
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced.
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
KO=0 LI=73 HI=43 OR=0-100 %
Engine Oil Temp
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F05F (00090005FFD8 alternate MTH found)
NAM: EOT
Engine hot KO=190 LI=190 HI=190 OR= -40 - 302 *F
Trans. Fluid Temp
TXD: 07E1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
NAM: TFT
Horsepower
TXD: 00
RXF: 400080000000
RXD: 0000
MTH: 000A00240000
NAM: HPR
Inj. Control Press. (ICP / HPOP)
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
Throttle Position 1 (Volts)
TXD: 07E0220917
RXF: 046245090617
RXD: 3010
MTH: 006404000000
NAM: TP1
Note: Voltage of the ETC Throttle Position Sensor number 1
KO=4.0 LI=4.0 HI=3.4 OR=0.7 - 4.2 VOLT Accelerator Pedal Track 1
Throttle Position 2 (Volts)
TXD: 07E0220918
RXF: 046245090618
RXD: 3010
MTH: 0064040000000
NAM: TP2
Note: Voltage of the ETC Throttle Position Sensor number 2
KO=1.4 LI=1.4 HI=1.9 OR=1.4 - 4.1 VOLT Accelerator Pedal Track 2
Throttle Position Desired (Degrees)
TXD: 07E022091A
RXF: 04624509061A
RXD: 3010
MTH: 0064020000000
NAM: TPD
Note: ETC Commanded Throttle Angle, in degrees.
Throttle Position Actual (Degrees)
TXD: 07E022093C
RXF: 04624509063C
RXD: 3010
MTH: 006402000000
NAM: TPA
Note: The measured throttle angle from the throttle sensor inputs.
EGR Duty Cycle (Percent)
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM: EGR
KO=0 LI=0-15 HI=32 OR=0-44 %
EGR Throttle Position Control Signal
TXD: 07E022096C
RXF: 04620509066C
RXD: 3010
MTH: 00647FFF0000
NAM: ETP
EGR Valve Position (mm)
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position.
EGR Valve Position Desired (%)
TXD: 07E02209D2
RXF: 0462050906D2
RXD: 3010
MTH: 00647FFF0000
NAM: EVD
EGR Valve Position Measured (%)
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT
EGR Valve Position (Volts 0-5)
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT
Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync)
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3000 (3001 alternate)
MTH: 000100010000
NAM: SYC
KO=0 LI=1 HI=1 OR 0-1 (NO/YES)
Intake Air Temperature 2 (Fahrenheit)
TXD: 07E02216A8
RXF: 0462051606A8
RXD: 3010
MTH: 000100010000
NAM: IA2
Engine HOT KO=113 LI=113 HI=113 OR= -40-250 *F
Manifold Air Temperature (F)
TXD: 07E02216E0
RXF: 0462051606E0
RXD: 3008
MTH: 00090005FFD8
NAM: MAT
Barometric Pressure
TXD: 07E0221127
RXF: 045285110627
RXD: 3008
MTH: 003100500000
NAM: BMP
KO=96.5 (14) LI=96.5 (14) HI=96.5 (14) OR=50 - 120 (7.3 - 17.4) kPa (PSI)
Exhaust Back Pressure
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
Fuel Level
TXD: 007E02216C1
RXF: 0462451606C1
RXD: 3010
MTH: 000101480000
NAM: FL
Volume Fuel Desired
TXD: 07E0221411
RXF: 046245140611
RXD: 3010
MTH: 006400100000
NAM: VFD
Mass Fuel Desired (Milligrams Per Stroke)
TXD: 07E0221412
RXF: 046205140612
RXD: 3010
MTH: 000100100000
NAM: MFD
KO=0 LI=7.5 HI=10.7 OR=0-100
Engine Run Time (Minutes)
TXD: 07DF011F
RXF: 0441051F
RXD: 2810
MTH: 0001003C0000
NAM: ERT
Fan Speed Sensor (RPM)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
KO=0 LI=533 HI=488 OR=0-4000
Fan Speed Sensor Duty Cycle (%)
TXD: 07E022091F
RXF: 04624509061F
RXD: 3010
MTH: 013103E80000
NAM: FDC
Manifold Absolute Pressure (PSI) (BOOST)
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: PSI
MAP is a standard gauge - but this XGauge is actually better than the standard one. It has a larger range which was needed because the standard gauge tops out around 37 psi absolute (about 22 lbs of boost), which diesels have no problem doing. This one should read well beyond 22lbs of boost.
With a little tweaking you can adjust this to read boost as you said.
To do this, just plug in the MAP code - get a reading from it with the key in the on position but the engine off, then based on the reading changed the last 4 digits of the MTH to whatever corresponds to your reading on this table
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
So, for example if you got a reading of 14.5 PSI with key on engine off you'd change the MTH to 01220320FF6F and the reading should read 0.0 with key on engine off and would then show how many lbs of boost you were at when the vehicle is running.
Injector Timing Before Top Dead Center (Degrees)
TXD: 07E02209CC
RXF: 0462850906CC
RXD: 3010
MTH: 000A00400000
NAM: ITM
KO=0 LI=-8.71 HI=+3.5 OR-50 - 50 ANGLE (Degrees) Injector Timing (TDC)
( not sure about the above)
Fuel Injector Pulse Width (Microseconds)
TXD: 07E0221410
RXF: 046205140610
RXD: 3010
MTH: 000800010000
NAM: FPW
Fuel Injector #1 Commanded (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3001
MTH: 000100010000
NAM: FI1
Fuel Injector #2 Commanded (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3101
MTH: 000100010000
NAM: FI2
Fuel Injector #3 Commanded (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3201
MTH: 000100010000
NAM: FI3
Fuel Injector #4 Commanded (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3301
MTH: 000100010000
NAM: FI4
Fuel Injector #5 Commanded (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3401
MTH: 000100010000
NAM: FI5
Fuel Injector #6 Commanded (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3501
MTH: 000100010000
NAM: FI6
Fuel Injector #7 Commanded (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3601
MTH: 000100010000
NAM: FI7
Fuel Injector #8 Commanded (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3701
MTH: 000100010000
NAM: FI8
COUNTS MISFIRES IN EACH CYLINDER
Cylinder #1 Cumulative Misfires
TXD: 07E022160E
RXF: 04620516060E
RXD: 3010
MTH: 000100010000
NAM: 1CM
Cylinder #2 Cumulative Misfires
TXD: 07E022160F
RXF: 04620516060F
RXD: 3010
MTH: 000100010000
NAM: 2CM
Cylinder #3 Cumulative Misfires
TXD: 07E0221610
RXF: 046205160610
RXD: 3010
MTH: 000100010000
NAM: 3CM
Cylinder #4 Cumulative Misfires
TXD: 07E0221611
RXF: 046205160611
RXD: 3010
MTH: 000100010000
NAM: 4CM
Cylinder #5 Cumulative Misfires
TXD: 07E0221612
RXF: 046205160612
RXD: 3010
MTH: 000100010000
NAM: 5CM
Cylinder #6 Cumulative Misfires
TXD: 07E0221613
RXF: 046205160613
RXD: 3010
MTH: 000100010000
NAM: 6CM
Cylinder #7 Cumulative Misfires
TXD: 07E0221614
RXF: 046205160614
RXD: 3010
MTH: 000100010000
NAM: 7CM
Cylinder #8 Cumulative Misfires
TXD: 07E0221615
RXF: 046205160615
RXD: 3010
MTH: 000100010000
NAM: 8CM
Gear (Transmission Gear)
TXD: 07E12211B3
RXF: 0462051106B3
RXD: 3008
MTH: 000100020000
NAM: GER
Self explained
Vehicle Speed Sensor (MPH)
TXD: 07E02211C1
RXF: 0462051106C1
RXD: 3010
MTH: 000102000000
NAM: VSS
Self explained
Accelerator Pedal Position (%)
TXD: 07E02209D4
RXF: 0462050906D4
RXD: 3008
MTH: 000100020000
NAM: AP%
Key On=0 LI=0 HI=13 Op range=0-17.75 (mine reads up to 99%, not sure why)
DTC Count (Diagnostic Trouble Code Count)
TXD: 07E0220200
RXF: 046205020600
RXD: 3008
MTH: 000100010000
NAM: DTC
Counts trouble code cycles
KO=0 LI=0 HI=0 OR=0 - 255
VREF (Calibration Voltage Input)
TXD: 07E0221155
RXF: 046245110655
RXD: 3010
MTH: 006433330000
NAM: CVI
KO=4.9 LI=4.9 HI=4.9 OR=4.5 - 5.5 VOLTS Reference Voltage
Net Torque into Torque Converter (Ft-Lbs)
TXD: 07E02209CB
RXF: 0462050906CB
RXD: 3010
MTH: 000100010000
NAM: TRQ
