No ICPV
Old Nov 17, 2014 | 02:31 PM
  #91
BryanStein's Avatar
BryanStein
Originally Posted by IHateCommieCars
For wasting y'all's time. This one was user error. Checking the wiring this morning, as I messed with the FICM connections, the connector to #8 injector just came off. I hadn't pushed it in enough. Put it back and the truck runs great again, and all the codes cleared.
My only problems are the IPR -- still stuck in the low 30s at warm idle and never goes below that -- and I'm not getting any ICPV according to SG. IPR seems to work otherwise, never goes to 85 or 15.
Could both of those symptoms result from a bad ICP? I'm going to view Sean's voltmeter vids and figure out how to check ICPv at the sensor. Doesn't it reason that I must be getting some ICPv since the truck and sensors are all working? Could it just be a bad SG x-command setting?
Thanks for everyone's help. If there's ever anything I can do for anyone down here in Houston, please don't hesitate to ask.
It could be a bad ICP sensor. If so, you may be running in default mode.
the IPR operating range is 15 to 85%. However, if running in default mode, I would not think the IPR would change.
I don't know if you've entered the ICPV Xgauge correctly, but if you haven't, that could explain it. That would surly be the first think I'd check.
Old Nov 17, 2014 | 05:34 PM
  #92
IHateCommieCars's Avatar
IHateCommieCars
[QUOTE=BryanStein; It could be a bad ICP sensor. If so, you may be running in default mode.
[I]That's what I'd think too. What causes IPR to be too high - an oil leak? But wouldn't even a small oil leak cause a no-start or some other symptom?[/I]
I have the settings right - or at least the ones Money Pit gave me. Not sure where he got them; they're not provided on the SG site that I saw.
Old Nov 17, 2014 | 10:47 PM
  #93
04badford's Avatar
04badford
ICPV= ICV
txd=07e02216ad, rxf=0462451606ad, rxd=3010, mth=004827100000
I think in your last Thread you said this one you have tryed
Old Nov 17, 2014 | 10:53 PM
  #94
IHateCommieCars
Originally Posted by 04badford
ICPV= ICV
Yes, those are the settings I used.
Can the truck run without ICPvolts? Or, since it runs, does that mean I have ICP volts, and SG is just not reporting it for some reason?
Old Nov 17, 2014 | 11:00 PM
  #95
04badford's Avatar
04badford
I had my SG set for a few things for example map I found I had 2 maps one read 0 and the other had Values , scroll through and see if this is the case
Old Nov 17, 2014 | 11:03 PM
  #96
IHateCommieCars
Only have one ICV set up.
Old Nov 17, 2014 | 11:09 PM
  #97
04badford's Avatar
04badford
OK , just had a new brain cell grow , dam now I have to wait another week for a new one
Old Nov 17, 2014 | 11:11 PM
  #98
IHateCommieCars
LOL, be glad you're young enough to still be growing brain cells. I'm losing mine every day.
Old Nov 18, 2014 | 12:49 AM
  #99
Yahiko's Avatar
Yahiko
Have you looked into that test harness that Diesel Tech Ron
said to use?
Here is that link again for those that misses it the first time around
http://www.ebay.com/itm/271432624076?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
$19.95 not bad.
Sean
Old Nov 18, 2014 | 11:41 AM
  #100
IHateCommieCars
said to use?
6 0L 7 3L Powerstroke High Pressure Oil Gauge Wiring ICP Test Harness | eBay
$19.95 not bad.
Sean
Yeah, that's a fair price. I used a voltmeter to check it. Like DTRon said, I confirmed I had the meter set right by checking the battery first, then probed each of the three wires. One was obviously the VREF and pegged at 5.0v, the other two (neither was red like in DTRon's vid) both registered 0.02. Since I know one is ground, it appears whichever one is the ICPv lead is grounded as well.
So, does that mean the next step is to find the PCM pin and phm (dang, I don't even know what that means exactly) it to see if the problem is the wire? If the wire's good, then my sensor is bad?
Old Nov 18, 2014 | 12:28 PM
  #101
WatsonR's Avatar
WatsonR
I'd look for a bare wire or a spot that may be chaffed. Both the ground and the ICV wires should run next to each other, the ground may be touching the voltage wire because they do run next to each other.
You could check the output pin to verify it's out putting the voltage, you've verified it's not getting there already, now it's just a matter of finding where in the wire run its damaged or that the correct voltage isn't being sent.
Old Nov 18, 2014 | 01:17 PM
  #102
IHateCommieCars
Hmm, admittedly I know little about electricity, but if I understand the previous posts, that VREF voltage is the juice coming to the sensor from the PCM. The ICPV is what goes back to the PCM. So, I know voltage is getting to the sensor, just don't know that it's sending back to the PCM. However, my SG does show seemingly good ICP values - they fluctuate up and down in relation to the throttle changes as I'd expect, so I don't know how that happens unless the ICP is sending. If that was only the "inferred" data, wouldn't it basically stay the same?
I think using an ohmmeter would test whether the wire was clear back to the PCM. If so, it must be a bad sensor.
I'm a bit confused since I just had it at the Ford dealer for diagnosis and he didn't say anything was wrong with the ICP. I've only made one trip since then.
Can anyone tell whether this cheap multimeter I bought can test the wires for grounding/disconnect?
Old Nov 18, 2014 | 01:58 PM
  #103
WatsonR's Avatar
WatsonR
if you put the meter to the ohm setting (20k) and test from end of wire to end of wire... an open wire or disconnected wire would read high as in max value. If the wire is good from end to end it would read very low as in .xxx and not xxx. A high reading means a broken wire, low means good wire.
Make sense?
Old Nov 18, 2014 | 02:00 PM
  #104
IHateCommieCars
Make sense?
Is the Ohm settings that horseshoe looking symbol on my meter?
Old Nov 18, 2014 | 02:37 PM
  #105
WatsonR's Avatar
WatsonR
yes it is....
