High boost at start
Old Aug 30, 2014 | 06:05 PM
gnrunner70's Avatar
gnrunner70
High boost at start
I'm having an issue where my boost reads 10.0-11.0 at start up then climbs up into the 20s as I drive. If I come to a stop or go below 5 mph the boost reading drops to 0. Normally the boost reading shows a range of 0 to 6 or 7 and up to 12-14 if I get into the throttle too much. Its not as simple as a bad reading, I can tell the truck is more responsive with the higher boost.
I've replaced the up-pipes, boots, ICP, IPR and have the EBPV unplugged. I can't recreate the condition so troubleshooting has been a pain. Any help or ideas would be great.
2002 F350
4 inch turbo back
AFE open filter
Edge programmer
All else is stock
Old Aug 30, 2014 | 06:55 PM
Pikachu's Avatar
Pikachu
Where is the boost reading coming from?
Tugly's Avatar
Tugly
What are you using to read the boost? Gauge? Scan tool? What kind? If it's a gauge, how is it tied into the engine?
Old Aug 31, 2014 | 08:02 AM
gnrunner70's Avatar
gnrunner70
I'm going off the Edge programmer so I think it's getting input from the MAP sensor.
Old Aug 31, 2014 | 08:08 AM
Tugly's Avatar
Tugly
Ah.... With everything you describe, it's more likely you have something going on with a connection, the MAP sensor, or a combination of problems that involve a boost leak. There is no method I can think of to actually build 10 PSI boost at idle.
Old Aug 31, 2014 | 08:16 AM
Pocket's Avatar
Pocket
Impossible to build that much boost at idle. Its an electrical issue somewhere. If your Edge is reading it, then so is the PCM.
Which makes sense as to why the truck feels snappier. The tuning by default limits the fuel in low boost situations in order to reduce tailpipe emissions and black smoke. But if the PCM sees higher boost, those fueling restrictions are eliminated. So your truck feels quicker as a result.
Old Aug 31, 2014 | 08:33 AM
gnrunner70's Avatar
gnrunner70
I'll double check all the connections, maybe something is loose. Other than the MAP sensor are there other sensors that influence boost pressure and could apply in my case?
Thanks for all the feedback
Old Aug 31, 2014 | 09:46 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Bummer. You would been better off by replacing the Edge programmer. That is where your problem reading is coming from
Originally Posted by Pocket
... If your Edge is reading it, then so is the PCM.
Correct. My Bully Dog programmers and chips did the same thing. They modify the look up tables for things like MAP to get the PCM to offer up more fuel then necessary. Depending on the setting, I'd see boost readings on my AE ranging from -5 to 15 psi at idle. That is why I dislike many of those programmers.
Clever tuners will also modify the MAP table to work around the defueling issue at higher boost levels but they do it in such as way as to preserve the absolute value of the reading.
Old Aug 31, 2014 | 09:51 AM
gnrunner70's Avatar
gnrunner70
I'll try removing the Edge for a few days, see if it reoccurs.
Kdawg89
Aug 3, 2015 05:07 PM
KIDkiser
May 12, 2014 06:38 PM
1eyedjack
Feb 15, 2013 03:32 PM
AJB201
Dec 17, 2011 08:43 AM
jimwilsonmasonry
Jan 2, 2009 12:28 AM
