Boost
Old May 12, 2014 | 10:30 AM
KIDkiser's Avatar
KIDkiser
Boost
I was just playing around and noticed on the scangauge that I'm only pulling about 20 pounds boost unloaded.when I first mash the peddle it jumps up to about 22 then back down to 20 and holds there,now this is not very far probably 800 feet and starting from about 55 mph.truck runs fine picks up speed fast,just thought maybe it should pull more boost.
Old May 12, 2014 | 10:43 AM
9228.bobcat's Avatar
9228.bobcat
I dont think the scangauge is very accurate on the boost. I believe it goes by your map sensor
Old May 12, 2014 | 12:24 PM
69cj's Avatar
69cj
The factory boost gauge is one of the few stock gauges that I actually trust.
Old May 12, 2014 | 12:51 PM
Jmoen7's Avatar
Jmoen7
Right around the 20 psi boost max is where people start seeing low power under heavy load and throttle, if you dont have that, your fine
Old May 12, 2014 | 06:38 PM
cheezit's Avatar
cheezit
Kind of normal with an egr delete. Flow more air you have less restriction. Lower boost in this case would not indacate an issue
Rod Jr.
Jan 28, 2019 11:16 AM
derek0525
13
Jan 19, 2016 03:57 PM
jimwilsonmasonry
Jan 2, 2009 12:28 AM
cdiddy
29
Feb 7, 2008 12:26 PM
Chance_Thomas
Apr 24, 2007 03:10 PM
