boost?
Old Jan 1, 2009 | 05:07 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
boost?
i hooked up a boost gauge in my truck and the best ive seen is 23 psi and the needle moves back and fourth rapidly is that normal -my boost psi sounds a little under par with what you guys are makin
Old Jan 1, 2009 | 05:16 PM
Welk49's Avatar
Welk49
Little unsure about boost numbers, they don't seem to bad for stock sticks. Someone else will chime in with a better knowledge than me I am sure.
Old Jan 1, 2009 | 08:12 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Where did you hook your boost line? The boost gauge should be steady.
Old Jan 1, 2009 | 09:23 PM
c00nhunterjoe's Avatar
c00nhunterjoe
best i can ever see is 20 right at the rev limiter.
Old Jan 1, 2009 | 11:26 PM
jimwilsonmasonry
i teed into the map sensor hose -to get past 20 psi i have to shift it myself
Old Jan 1, 2009 | 11:33 PM
c00nhunterjoe
mine is teed into the map line as well and i have to hold the gears out manually to hit 20 psi as well. if i let the truck shift on its own i may see 17-18 for a split second
Old Jan 1, 2009 | 11:39 PM
jimwilsonmasonry
thats about what i get as well lettin it shift itself but should my needle move rapidly back and fourth that just dont seem right
Old Jan 1, 2009 | 11:55 PM
c00nhunterjoe
i've seen that happen before, normally its just the gauge, what kind of gauge is it? got a warrenty on it?
Old Jan 2, 2009 | 12:18 AM
jimwilsonmasonry
its a sunpro gauge
Old Jan 2, 2009 | 12:28 AM
c00nhunterjoe
i would bet its just the gauge
bleeds blue
Apr 29, 2014 06:56 PM
jleal_21
Apr 11, 2010 08:25 AM
dieselsmoker
Dec 23, 2008 09:48 PM
crazymut
Sep 5, 2008 11:59 AM
maevans
Oct 6, 2005 08:59 PM
