Normal boost psi
Old Feb 14, 2013 | 08:04 PM
1eyedjack's Avatar
1eyedjack
Normal boost psi
Hello all,
Quick question abut boost psi on the powerstrokes. When I first start my truck my boost gauge on my edge cts reads 1 to 2 psi then drops to 0. I take off on the road and driving about 30 mph on my dirt road it says 7 psi then I hit the interstate and drive 75 mph and it will read 10 - 11 psi then it will slowly drop. The other day I was driving into the wind on I-25 here in northern Colorado and I noticed my boost was at 18 psi. Are these reading normal? I have a stock 05 f250 with only a coolant filter setup.
After reading all the boost threads on here I am thinking that I might have a leak or my turbo is sticking? What you guys thinking?
Thanks
Old Feb 14, 2013 | 11:02 PM
Roasted7's Avatar
Roasted7
There are a lot of factors involved when driving, but at startup and idle it should be 0.
Old Feb 15, 2013 | 05:38 AM
MC5C's Avatar
MC5C
Mine acts about like yours. 18 psi just because of wind sounds high, but depends on the wind I guess. I see max boost of 28 psi, this is on my dash gauge.
Brian
Old Feb 15, 2013 | 08:06 AM
livinlots26's Avatar
livinlots26
Mine is about the same using an edge tuner for boost readings. I will get up to 30psi when I really harp on it but I might have some sticky vanes cause I feels like it takes awhile to build that.
Old Feb 15, 2013 | 08:27 AM
69cj's Avatar
69cj
30 on a stock motor is testing your headgaskets. Should be 28 max.
Old Feb 15, 2013 | 10:06 AM
livinlots26
Got arp studs! Blew them awhile ago and after an egr delete coolant filter arp studs and new coolant cap all has been well... knock on wood.
Old Feb 15, 2013 | 11:16 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Depends on a lot of factors, even on cruise control the boost will change whether there is tail wind or head wind, going up or down hills.
Josh
Old Feb 15, 2013 | 03:32 PM
1eyedjack's Avatar
1eyedjack
Ok, I have read all your reply post. It seems like mine is running normal. Wheeeew. Thanks everyone.
Rod Jr.
Jan 28, 2019 11:16 AM
Teds
Jul 22, 2012 03:14 AM
jimwilsonmasonry
Jan 2, 2009 12:28 AM
Bin Strokin
19
Jun 15, 2008 08:28 PM
