Updated Torque PIDs
Old Aug 21, 2015 | 05:47 AM
  #196
Tugly's Avatar
Tugly
I'm glad you got that solved. I use EGP and MGP (boost) on Stinky every time I drive. From what I've learned, there are combinations of PCM, tablet, app, and OBDII adapter that do not behave the same as others.
Old Sep 17, 2015 | 07:30 PM
  #197
makemeknowit's Avatar
makemeknowit
Ok, major frustration here. I got a new phone, xferred all my stuff over from the old one. Torque WILL NOT give me trans temp. Version on the new phone is the same and updated. I didn't have to do anything special to get trans temp on the old phone, added the gauge and all was well. I have 2 "Transmission Temperature" options and 2 "Transmission Fluid Temperature" options in the old phone. New phone doesn't have the latter. I've added the PID in the new phone and I'm still getting nothing. Trans temp was the #1 reason I bought the dongle and app. Any suggestions?
Old Sep 18, 2015 | 06:22 AM
  #198
Tugly's Avatar
Tugly
I ran into the same problem with Engine Oil Temperature one time. I had to strip out Torque Pro, run all the updates, then re-install TP and manually program all my PIDs from scratch. It was a total PITA, but it worked. I can't promise this will work for your situation, but there it is.
Old Sep 18, 2015 | 08:11 AM
  #199
carl2591's Avatar
carl2591
is there a way to save all the PIDs / gauges you have installed on your tablet vs have to start from scratch.. man that is a lot of work putting it all back.
Old Sep 18, 2015 | 09:13 AM
  #200
Tugly's Avatar
Tugly
Yes, but I can't remember the exact procedure off the top of my head. I believe you export the settings, then you can import them. I also know that if you install an explorer app, you can look at all the files on your phone like a PC. I did that with my Nexus 7 and I can dig around in there all I want - copy, paste, etc....
Saying that, we don't know where the problem is. To rephrase - we don't know where the 1 was supposed to be a 0 (or visa-versa), and copying straight over could import the same error. You can try it - but I can't answer if the PITA trophy won't reach your mantle.
I assume you looked everywhere in the PID setting for a typo.
Old Mar 14, 2016 | 07:08 PM
  #201
Fadetooblack's Avatar
Fadetooblack
Big thanks to Tug and Pik for doing all this work, was able to put Torque with BAFX dongle in my 1996 and have it working with no issues.
Torque Pro in 1996 F350 with 84,000 miles.
Old Nov 22, 2016 | 03:31 PM
  #202
queen of spades's Avatar
queen of spades
Is there an app on Play that automatically sets up all of these PIDs?
Or does someone have a CSV of all of the current PIDs they could share?
Old Nov 22, 2016 | 03:46 PM
  #203
queen of spades
Good lord. Finally found the CSV. It's linked to originally in this Chipworkz post:
https://www.ford-trucks.com/forums/1...l#post15814573
The direct link to the CSV file is:
https://drive.google.com/file/d/0B7o...NVT19lZ0E/view
Old Dec 17, 2016 | 08:46 PM
  #204
Jaime74656's Avatar
Jaime74656
Is the Csv file all we need to use for loading gauges? Rich are you still planing on posting up your Torque gauge set up? I know we talked about doing so at one time via pm or am I thinking of something different here?
Old Dec 18, 2016 | 08:41 AM
  #205
Tugly's Avatar
Tugly
I finally have a huge gap in my workload for the holidays, so I can finally take some time with my tablet. I'm also due for the 2017 update soon anyway.
Old Sep 30, 2017 | 08:16 AM
  #206
MeTo's Avatar
MeTo
I know this is an old thread, but? Does anyone have the IAT working on an OBS?
This is what I have:
IAT:
Mode/PID: 22114A
Long name: IATf OBS
Short name: IATf
Min value: -20
Max value: 150
Scale: x1
Unit: °F
Equation: (((A*256)+B)*-0.00314)+193.34
Header: C410F1
comments: 24/02/2014
Old Oct 1, 2017 | 09:01 AM
  #207
Tugly's Avatar
Tugly
I still haven't locked down in which years this is true, but my experience has shown I must use the correct PID number and correct long name for the PID to work. You can use whatever short name you want, but it's my understanding the long name must be "official" - like intake air temperature.
Old Oct 1, 2017 | 09:33 AM
  #208
MeTo's Avatar
MeTo
Thanks for that.
Hmm, when I try to add a custom pid (intake air temperature) it states their is a pid with that name. It doesn't appear in the Ford pid list, but is available when I add a gauge??? I can't edit or find that one.
Old Oct 3, 2017 | 10:41 PM
  #209
Blueforester's Avatar
Blueforester
Manage custom OBD2 PIDs
First post in years. But always using this great forum. I've downloaded the csv file and a file explorer.
1. I cannot find the folder previously mentioned "On my device it is sdcard\.torque\extendedpids" so I copied in the .torque folder and in several folders
2. When I go to Torque Setting and select Manage extra PIDs/ Sensors it comes up with Press 'Menu' to add extra OBD PIDS. Where the heck is the Menu??
Been so long do not know if I have a signature block or if updated. But I have an 02 7.3 bought new back in 02/02. About 182k miles. I've enjoyed playing around and upgrading over the years. Running strong as ever. Well actually stronger now. Was a dog in 02/02.
Blue
Old Oct 4, 2017 | 07:03 AM
  #210
Tugly's Avatar
Tugly
These apps keep changing icons for "Settings" and "Menu", but the last couple of years things have pretty much settled down to a gear and/or wrench for "settings"...
and three bars for "Menu"...
The three bars are a glimpse into the future. This is what a list looks like to an old fart like me without his reading glasses.
