Indeed, Tre Cool. I just got all my gauges to work with any kind of stability. I think I shall leave the code experimentation to Bigger Brains than mine. Now on to Logging!
Both the hpo and turbo custom pids seem like an awesome idea. The lower HPO pressure causes less atomization. This has always concerned me on hybrid injectors because the pressure ratio is 5:1 rather than 7:1. That would need to be factored into the PID I would think.
I would imagine the hybrids might be a bit more smoky than a conventional stage II, but they work.
As far as factoring it in... HPOI is more of a hog rootin' out troubles, not trifles. It should work on hybrids, but it might land on a different "cusp" number than 10.
It is interesting to think about because (if I understand the intent of the HPOI correctly) you are basically trying to qualitatively measure how atomization of the fuel with the HPOI gauge. A hybrid injector will use less oil, so you should be able to hold the oil pressure better, but the atomization would drop off quicker with less oil pressure.
Naw - ICP is straight-up your number for atomization... that's why it's there.
HPOI is a formula I've worked out to "share what I know" about the whole HPO and injection system. Instead of people needing to email or post data sets to AE readers to figure out why their truck is hot, sooty, and anemic with a 140 HP tune, HPOI will let the driver know it has something to do with the HPO system. The driver would then start focusing there, instead of being bewildered.
Are you referring to transferring the logging settings to another device?
I can tell you the logging settings lock in when you set them, until you "unset" them. It's not like Giotto, where you have to program the logging each and every time.
I want to change it to log just 2 or three to see if I can get more samples per second for a specific test.
Then I want to go back to the 20 pid logging setup.
Ideally, I would just save the 20 PID logging configuration and then create the 2 pid logging configuration. When I'm done with my lest I can just load the 20 PID configuration back in.
Otherwise, I have to write them all down (so I don't forget which ones I had) and then add them all in one at a time.
Tugly, That dredges up another question I had....The vehicle profiles Tab. Is that a master Listing for the entire program, or is there a separate list for the logging section.(and torque scan for example)?
Oh, and another...How many PIDS will TP log at one time? I only seem to be able to pull one or two at a time...
For the life of me I can't get these two to read correctly on my rig. I have a 2000 zf6 and the oil temp only gets to 100 . @ the trans temp just stays at 3 . Any ideas?
