Cummins swap/frame question
I have most everything needed to make it fire up and run, just gotta get it all together and hook up a battery.
Hope it doesn't take too long to get the fuel system bled. I'd love to make smoke with it this weekend.
By making it run before installing, it should be quite easy to get it running again once it's in.
Indeed, it would be a major milestone though.
But, I filled the shop with smoke today. Didn't take long to make it hard to see/breathe either...... I suppose having put ATF directly into the cyls before turning the engine over had a lot to do with the smokey fire up. At least the rings had some lube.
Took a bit longer to get the fuel system bled than what I had expected. The mechanical pump on the side of the block just did not want to pick up any fuel. So, I took off the output line, put my finger over the outlet port, and pumped it till fuel came out.
That done, it didn't long at all to get the injection pump and lines mostly bled out.
I had to hook up 2 batteries in order to get it to turn over fast enough to light off, most likely due to not having a real good battery laying handy.
First time it lit, it only ran a few seconds, which was kinda surprising since all 6 injector lines were still loose. It started on just the residual ATF in the cyls, and boy did the smoke roll.......
Once the smoke thinned out a bit, I cranked it over till fuel started spraying from the loose injector lines, and tightened each line as fuel showed up. After having fuel at 4 of the 6 injectors, it fired up, again filling the shop with smoke.
I didn't let it run very long, and it's still not quite hitting on all 6. I haven't yet adjusted the valves, so I'm planning to get that done, and give it some more run time, though it may be next weekend before that happens.
Been a pretty good day, if ya ask me.....
Subscribed - now I can start reading from page 1.
-BlueBruiser.
I moved in Nov '14, and had no internet access until very recently.
I spent way more time & effort locating stuff and tinkering with the engine/trans than I intended to. The truck hadn't seen much progress since I moved, until yesterday.
I put the trans back together with the new 5th gear nut, installed a new input shaft, and got it ready to go in.
Put the new clutch on the back of the engine, and with the assistance of my son, we bolted the engine trans together. Then we lifted them up, and set them into the chassis. The engine mounts I had planned, will not work.
As of last night, the engine and trans are sitting in the chassis, with the engine mount brackets resting on the frame stands, and the trans mount location resting on the crossmember which is simply sitting on the lower frame rails. The entire weight of the combo is sitting directly on the frame, although a few inches higher than the final location will be, and the hood will still clear the top of the engine with the turbo outlet to intake manifold crossover tube in place.
The next step will be fabricating new engine mount brackets for the engine that will allow it go down lower. There's still ~6" between the oil pan and front crossmember, so there's quite a bit of room to go lower, and I want to set it as low as possible. Oil pan width may be the only thing that limits how low I can get it.
FWIW, the front springs that were way too stiff under the 300/C6 combo, keeping the front tires cambered out up top, are likely going to be just right under the 6BT/NV4500 combo. With the full weight on the frame, the front tires are almost perfectly vertical, and the there's no rad support or rad, bumper, or engine accessories (A/C, Alt, Vacuum/PS pump combo) bolted on yet.
On the truck, you are making good progress, albeit somewhat later than you expected. You'll get there, and soon I'm sure.
I have a wireless service, and it's a bit pricier than most wired services, and slower, but still way better than dial-up. Signal quality can sometimes be an issue, particularly in windy conditions, but at least I can access the web from home.
I have a tablet style PC at the shop, but the screen is too small to really be able to read forums and such on, especially compared to the 32" LED TV I have here at the house, in use as a monitor.........
I likely won't be on a lot, as I have a lot of stuff to keep me occupied these days, but I'll still be on 2-3 times a week hopefully.
Got in the car and started out of the parking lot, drove past the ford, at which point I pointed out the big "C" logo badges on the sides of the fenders.
He decided that I was correct, as usual........
Those common rail cummins have a rather distinctive sound to them, even from a couple hundred yards away.
On another note, he is considering buying a 93 F150 that the boss has. It's a 300/5 speed. Would make a great candidate for a 4BT swap down the road, when the 300 finally dies. Might be a while though, as it only has ~250K on it.........
And, I think your dad would respond to you with: "If that was meant as a compliment, then I thank you".
