Why a coolant filter can damage your engine?
Old Dec 11, 2013 | 08:04 AM
  #106
Snowseeker's Avatar
Snowseeker
If you pull all the freeze plugs out is it an air cooled motor?
Old Dec 11, 2013 | 08:41 AM
  #107
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Originally Posted by BryanStein
Beachbum, I'm sorry to hear your coolant filter has kept you from getting 100k miles out of your truck.
In all seriousness, if you change coolant yearly or every 50k miles, it likely does not master which coolant you use. This includes the green stuff. The green stuff is silicate based. Isn't the green stuff the same as Ford Gold but not as environmentally friendly?
Not sure of the exact answer, but I know from owning my truck since 2003 that green and gold are two different chemisty's and not compatible with our 6.0L motors.
However, one can use Premium Gold coolant in an older 7.3L motor (after flushing all green coolant out as the two types do not play well together).
The Gold coolant has some extra "anti-cavitation" benefits and allows for longer service intervals, however, Ford learned that the 6.0L motor beats the hell out of the coolant and was forced to issue an updated/reduced service interval a few years back.
Flushing one's coolant is necessary, but any solids, sand, particulates, will collect and stay in the "low points" of your system when the motor is off and de-pressurized. However, these "particles" are suspended and move through your cooling system and motor when at operating temps and the system is pressurized... and this is where and why a coolant filter works so well... it's picking up the particles as they are suspended and moving through one's cooling system!!!!
Flushing with distilled water (tap water will have minerals in it that can be found in some filters) is good, but also using a coolant filter is just better, but is not a substitute for changing the coolant on time or ahead of schedule.
Old Dec 11, 2013 | 08:44 AM
  #108
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I wouldn't use Ford Gold G0-5 in an air cooler lawn mower.
Josh
Old Dec 11, 2013 | 09:22 AM
  #109
Money-Pit's Avatar
Money-Pit
Josh
No reason to....it's air cooled. If you put coolant in an air cooled motor, it will sufficate & drown.
I thought everyone knew that?
Old Dec 11, 2013 | 09:38 AM
  #110
Snowseeker's Avatar
Snowseeker
Thats just if you dump it in to fast. While running you just trickle the coolant in and all will be good.
Old Dec 11, 2013 | 09:40 AM
  #111
Money-Pit's Avatar
Money-Pit
Sunnovabitch.....I learn something new everyday on FTE.
I love this place!
Old Dec 11, 2013 | 09:53 AM
  #112
Bullitt390's Avatar
Bullitt390
Ford Gold is good for ridding the neighborhood of mice and stray cats...
Josh
Old Dec 11, 2013 | 10:29 AM
  #113
Snowseeker's Avatar
Snowseeker
Will it get rid of the cat under my 6.0?
Old Dec 11, 2013 | 10:55 AM
  #114
MisterCMK's Avatar
MisterCMK
Originally Posted by Mr.Nobody
If you really want to boost your cooler longevity (oil and EGR). A hand full of peat goes a long way. Easy to get too, Home Depot has 50 pound bags, should be enough "additive" for several sand flushes. Warning, if you perform this mod, you need a custom degas cap that can vent the gases generated by decomposition of the peat.
My EGR cooler is going to last indefinitely. It is a secret method though.
Old Dec 11, 2013 | 10:57 AM
  #115
Rusty Axlerod's Avatar
Rusty Axlerod
Ford has a line of coolants labeled as "Premium" and still has coolant labeled as "Gold" but there is no longer any such thing as "Premium Gold" unless you run across some that's been on a shelf for a year and a half or longer.
Old Dec 11, 2013 | 11:00 AM
  #116
Bullitt390's Avatar
Bullitt390
I have it on good word Hitler was the mastermind behind G0-5 coolant. One of the reasons they lost the war I hear.
Josh
Old Dec 11, 2013 | 11:05 AM
  #117
BLADE35's Avatar
BLADE35
I love it Definatly a NO Nonsense thread here
Old Dec 11, 2013 | 12:03 PM
  #118
Snowseeker's Avatar
Snowseeker
How about kesslers, Jim bean, or bacardi 151?
Old Dec 11, 2013 | 12:05 PM
  #119
Bullitt390's Avatar
Bullitt390
Southern Comfort won't drop silicates and clog the oil cooler
Russian 6.0 engines run Vodka for its superior freeze point.
Josh
Old Dec 11, 2013 | 12:07 PM
  #120
MisterCMK's Avatar
MisterCMK
A real man would run Everclear.
