Block Heater
Old Oct 24, 2013 | 08:28 AM
DHamSTER's Avatar
DHamSTER
Block Heater
Is there a long term effect on the engine if you pull your truck in every night and then while you are at work all day?
Or any effect at all?
Old Oct 24, 2013 | 08:34 AM
Brother Les's Avatar
Brother Les
instead of 'pull', I think that you meant 'plug'. No need to have it plugged in all night. Two hours before you need the truck will work fine. Have your truck hooked up to a heavy duty timer to come on about two hours before you need it. Will it 'hurt' it. Don't think so, just use a lot of electricity.
Old Oct 24, 2013 | 08:35 AM
Tugly's Avatar
Tugly
It might shorten the life of the block heater (they are good for so many hours of use). I put a timer on mine.
Old Oct 24, 2013 | 09:08 AM
DHamSTER's Avatar
DHamSTER
Shorten the life of the block heater meaning the element right?
Old Oct 24, 2013 | 10:07 AM
DHamSTER's Avatar
DHamSTER
Thanks btw. I'm new to the diesels and winter. I Just replaced the block heater power cord so I have a brand new heating element still in the box, so I do have a back up.
Old Oct 24, 2013 | 11:23 AM
Brother Les
The big thing about Diesels and winter starting ..... is your glow plugs..... which means you want to make sure that you Glow Plug Relay (GPR) is working correctly. Any questions on that?
Old Oct 24, 2013 | 11:28 AM
DHamSTER's Avatar
DHamSTER
I have done a few cold starts but the most significant one was last week. I tried to start it about 12 times before I got it to start....
Where can I find that relay? I'm sure that's cheaper than getting the plugs.
Old Oct 24, 2013 | 11:55 AM
diehardstroker's Avatar
diehardstroker
GPR is a about $45 for OEM from dieselorings and Motorcraft glow plugs are $10.88 a piece (you need 8) from dieselorings
if you have a good GPR but your glow plugs are shot then it still wont work properly. but you can have good plugs and bad GPR as well
Old Oct 24, 2013 | 11:57 AM
Brother Les
Get yourself a plug in volt meter that plugs into the dash power port. I bought this from Wally world..
INNOVA 3721 Battery and Charging System Monitor : Amazon.com : Automotive INNOVA 3721 Battery and Charging System Monitor : Amazon.com : Automotive
You should see the following reading if the GPR is working.
1) when plugged in you should see 12.5v
2) when you turn the key to on and the wait to start light comes on it should read 11.5v. glow plug relay is 'on'.... if the voltage does not 'drop' then you may have a problem with the relay.
3) when the 'wait to start' light goes out (and you had the voltage drop to 11.5v) if it is really cold then cycle the glow plugs again to get the chamber really hot. Now turn the key to start the truck. your voltage meter will drop to about 11v. If the meter drops below 10.5 the truck Will Not Start as you need at least 10.5v for it to start.
4) when the truck starts, the voltage should be 12.5v. When the GPR shuts off the voltage will slowly rise to 14.5v. this last number of the voltage is the output of the alternator.
5) Do you have any questions?
Old Oct 24, 2013 | 12:00 PM
diehardstroker
You should be able to see this with your torque app Dylan as it allows you to see the voltage
Old Oct 24, 2013 | 12:17 PM
DHamSTER's Avatar
DHamSTER
Thanks brother!
Great info! I'll look into it
DHamSTER's Avatar
DHamSTER
I hardly use that sucker. It's hard enough keeping one phone charged let alone 2.... Haha
Old Oct 24, 2013 | 01:19 PM
diehardstroker
Its worth charging to see if your gpr is working lol
Old Oct 24, 2013 | 04:09 PM
Km1210's Avatar
Km1210
This is what it looks like when you try to start your truck in winter temps with a bad GPR. This was my previous 7.3 with a bad Glow Plug Relay. White smoke is a good hint that your glow plugs are not working, in this case, my GPR wasn't working so neither were the glow plugs. I changed the relay, and fired first time every morning. And do yourself a favor and do the GPR LED as well so you can tell when your GPR is working. Link to GPR LED mod:https://www.ford-trucks.com/forums/7...wmriceman.html
Old Oct 24, 2013 | 04:14 PM
DHamSTER's Avatar
DHamSTER
Wow thanks!
Yea I was blowing huge amounts of white smoke....
