Normal values to match
map= koeo 14 lo-14 hi-15
icp= koeo-0 lo-625.5 hi-1400-1450
icv=koeo-0.2 lo-1.0 hi-1.8
ipr=14.84 lo-24 hi-40.60
flp=12.0 lo-13.5 hi-13.5
fmp=48 lo-48-hi-48
vgt=0 lo-73 hi-43
egr=0.8 lo-0.8-1.0 hi-1.3 egr valve position
egrdc=0 lo-0-15 hi-32 egr duty cycle
ebp=15 lo-16 hi-16
bst=epd 3.26 lo-2.43 hi-2.13 ep exhaust pressure desired
vref=4.9 lo 4.9 hi 4.9
some of these numbers don't and wont match the same but should be close testing values. my concern is ICPV ,map hi at 38, check EBP tap and ICP connection wiggle test . sorry guys for the long post
after repairing pig tail i now have BAR 14.3, just a thought but the P2262 code is related to MAP aint it? I Apologize for being frustrating (sometimes I am special)I went back out and did the test again at 2500 and MAP never went over 17 I had to have written something down wrong
If you minus the atmospheric pressure from the MAP 14.3-38= 23.7 psi boost.
i can re run the numbers but I am sure I screwed up and the 38 Map reading is wrong I tested just the MAP at 2500 and it peaked at 17...insert bonehead emoticon here
From my notes,
P2262 MAP Turbo/Super Charger Boost Pressure Not Detected — Mechanical CAC system leaks, MAP hose disconnected, exhaust system leaks, intake system leaks
Just out of curiosity at what point while driving should I be concerned of MAP readings? I watched it close this morning and was seeing 25 pretty consistantly while on the throttle.
