Some some help troubleshooting round two
Old Aug 19, 2013 | 09:02 PM
  #76
JWREO's Avatar
JWREO
Originally Posted by Bullitt390
That is your IPR%?
Josh
I checked the command 3 times that is what shows on the gauge, going to try and see what it means.....
Old Aug 19, 2013 | 09:13 PM
  #77
mustang_309's Avatar
mustang_309
NM im slow on the uptake.
Old Aug 19, 2013 | 09:47 PM
  #78
99ExpyProblems's Avatar
99ExpyProblems
Thanks for clearing up the 85% on the VGT when cold idle. Sorry I steered you in the wrong direction JWREO!
Old Aug 19, 2013 | 09:49 PM
  #79
JWREO's Avatar
JWREO
No worries, made me learn more that way!
Old Aug 19, 2013 | 09:53 PM
  #80
BLADE35's Avatar
BLADE35
Your using the Command Button on SGII???
You Should be doing X-Gauge Entry
Old Aug 19, 2013 | 09:56 PM
  #81
JWREO's Avatar
JWREO
don't know what else to call the greek that you have been sending me to plug into the gauge to get the readings you need LOL
Old Aug 19, 2013 | 09:59 PM
  #82
JWREO's Avatar
JWREO
just putting thoughts to words.... going to install EGR gasket and O-rings in morning, thinking I should check catalytic converter as well not sure it makes that much difference but at cruising speeds may be just enough blockage to cause trouble...any thoughts
Old Aug 19, 2013 | 11:50 PM
  #83
BLADE35's Avatar
BLADE35
Use the SGII EBP Gauge to see if there is any exhaust blockage
EBP will be high if exhaust is Blocked
But also remember that High EBP could be something else
Old Aug 19, 2013 | 11:52 PM
  #84
BLADE35's Avatar
BLADE35
Had any luck with the Programing of the IPR% Gauge??
Old Aug 20, 2013 | 12:43 AM
  #85
04badford's Avatar
04badford
Benny, Op had =VGT-Idol 85 ,lil hi, value 73 OEM with in range?
OP 2500 rpm=50 , OEM-43 lil high? with in range?
IPR=koeo=16.8 -oem=14.8 leak out of range>
ipr= lo=17.2 -oem=24 out of range .>
Old Aug 20, 2013 | 12:55 AM
  #86
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
VGT is slightly odd, but there have been many to show 80+ at idle.
OP's IPR % is whacked, no doubt about that.
Josh
Old Aug 20, 2013 | 01:05 AM
  #87
04badford's Avatar
04badford
Your right Josh VGT at that value = Is turbo Cleaning in Order. also new o-ring.
Old Aug 20, 2013 | 05:29 AM
  #88
mustang_309
It depends on when he took the VGT reading if the engine was cold 85% is ok, when the engine is up to temp it should drop in the low 70's at idle.
Old Aug 20, 2013 | 07:01 AM
  #89
JWREO's Avatar
JWREO
Ok Guys I took the truck on a ten mile warm up this morning to ensure she reaches operating temps here are the new readings:
KOEO
ICV .23
IPR 14.4
ICP 0
FMP 48
MAP 14.3
EBP 14.4
KOER
RPM 688-694
ICV .77
IPR 21.4
ICP 583
EBP 16.4
BST .3-.5
MAP 14.4-14.7
VGT starts at 74 falls to 85 slowly ( one point per second)
EGR 35 (not new gaskets)
On a side note the only time I saw VGT not rest at 85 is when I disconnected the MAP sensor VGT would then stay at 75. Not sure if that is relevant, but can't help thinking it is. While driving I watched ICP top out at 3990 at WOT, VGT would drop to 73 at a stop and then drop to 84.Thanks again for all your help! by the time I get through this one I will know this motor inside and out I'm thinking.
Old Aug 20, 2013 | 07:11 AM
  #90
mustang_309
What does your VGT% do when cruising at say 55 MPH? It should be somewhere in the 45 to 55% range.
