Some some help troubleshooting round two
Old Aug 17, 2013 | 03:26 PM
  #31
JWREO's Avatar
JWREO
going to go pick up scan gauge hopefully will have some vital info soon
Old Aug 17, 2013 | 03:29 PM
  #32
BLADE35's Avatar
BLADE35
Originally Posted by JWREO
definitely not running any better, going to attempt cleaning the egr valve, any suggestions
Best way to pull it is to use 2 small pry bars
Like this
Pry both bars together one each side opposing each other it will pop right out This works LOTS Better then the Wire method
It needs to be pry straight up this why 2 bars is best
1 Bar pry will pinch it in the hole and you will fight it
Old Aug 17, 2013 | 03:32 PM
  #33
BLADE35's Avatar
BLADE35
Sent a PM for Gauge Codes you will need to program into it
Edit it wont let me PM you WTF
you have 30 posts
Here is a Start
SGII ENTERING THE X-GAUGES FOR SETUP
V-REF
TXD=07E0221155
RXF=046245110655
RXD=3010
MTH=006433330000
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
Exhaust Back Pressure
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
BOOST (BST)
TXD= 07E0221440
RXF= 046285140640
RXD= 3010
MTH= 01220320****
NAME=Boost (PSI).
In order to get the proper boost value enter the MAP XGauge. Get a reading
from it with the key in the on position but the engine off. Based on the reading change
the last 4 digits of the MTH value that corresponds to your reading in the table to the
right.
12.6 - - FF82
12.5 - - FF83
12.4 - - FF84
12.3 - - FF85
12.2 - - FF86
12.1 - - FF87
12.0 - - FF88
11.9 - - FF89
11.8 - - FF8A
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
FICM Logic Power (Volts) (Should be 12 volts)
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 006401000000
NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced.
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 006401000000
NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 006401000000
NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
Inj. Control Press. (ICP / HPOP)
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
MAP and Volts should already be in the gauge.
MAP Voltage (Volts)
TXD: 07E0220900
RXF: 046205090600
RXD: 3010
MTH: 000104000000
NAM: MPV
Note: This one seems a bit odd, but try it out and let me know if you need finer resolution. This one will go by whole numbers, but the range is something like +/- 32 Volts which seems weird for a sensor – they’re usually 0-5 volts
EP Volts (Volts)
TXD: 07E02216AE
RXF: 0462451606AE
RXD: 3010
MTH: 000100800000
NAM: EPV
Note: This one may have weird readings if the values get to high, let me know.
Old Aug 17, 2013 | 06:30 PM
  #34
JWREO's Avatar
JWREO
THANKS!!!
Here is what I have so far:
FMP 47.5-48
FLP 11.5-13
ICP 580-590 at idle
EPV 5
still trying to get the other values....NO codes
Old Aug 18, 2013 | 07:05 AM
  #35
JWREO's Avatar
JWREO
FMP 47.-48.5
MAP 14.3 KOEO 14.6 idle
ICV 1.
FLP 11-13
ICP 578-590 Idle
let me know what else you need to see, I have taken it on a few runs trying to gt a code but nothing so far, still has miss between 1100 and 2000
Old Aug 18, 2013 | 08:43 AM
  #36
CPB1's Avatar
CPB1
How did the EGR valve look? Do you still have the EGR cooler, or an EGR delete?
Here are the misfire codes. You can watch four at a time. Not sure if it counts, or only shows them when it's missing.
COUNTS MISFIRES IN EACH CYLINDER
Cylinder #1 Cumulative Misfires
TXD: 07E022160E
RXF: 04620516060E
RXD: 3010
MTH: 000100010000
NAM: 1CM
Cylinder #2 Cumulative Misfires
TXD: 07E022160F
RXF: 04620516060F
RXD: 3010
MTH: 000100010000
NAM: 2CM
Cylinder #3 Cumulative Misfires
TXD: 07E0221610
RXF: 046205160610
RXD: 3010
MTH: 000100010000
NAM: 3CM
Cylinder #4 Cumulative Misfires
TXD: 07E0221611
RXF: 046205160611
RXD: 3010
MTH: 000100010000
NAM: 4CM
Cylinder #5 Cumulative Misfires
TXD: 07E0221612
RXF: 046205160612
RXD: 3010
MTH: 000100010000
NAM: 5CM
Cylinder #6 Cumulative Misfires
TXD: 07E0221613
RXF: 046205160613
RXD: 3010
MTH: 000100010000
NAM: 6CM
Cylinder #7 Cumulative Misfires
TXD: 07E0221614
RXF: 046205160614
RXD: 3010
MTH: 000100010000
NAM: 7CM
Cylinder #8 Cumulative Misfires
TXD: 07E0221615
RXF: 046205160615
RXD: 3010
MTH: 000100010000
NAM: 8CM
Old Aug 18, 2013 | 12:25 PM
  #37
JWREO's Avatar
JWREO
havent been able to pull EGR yet, got sidde tracked with wife and kids....the truck is bone stock; barring any major expenses it will have studs and egr/oil cooler taken care of next month. Thank you all for the scan codes! I'm worse than a kid at christmas playing with it...I will enter these misfire codes and see what it tells me...yesterday I pulled the charge pipe to clean the brass nipple for the MAP, I guess I didn't get it tightened back up enough because it popped of this morning when i went for a test run to track HPOP pressure....scared the crap out of me.
Old Aug 18, 2013 | 01:31 PM
  #38
JWREO's Avatar
JWREO
Just pulled EGR and Cleaned it....if it was working i don't know how, it was pretty caked up with soot. I ran the misfire codes, no cylinders reporting a misfire. I wil continue to research and monitor, I am adding archoil when it gets here..should be tomorrow. You guys have been a great help to me I hope I can return the favor someday.
Old Aug 18, 2013 | 01:47 PM
  #39
CPB1's Avatar
CPB1
Maybe cleaning the EGR valve solved the problem. Some EGR codes,
EGR Duty Cycle (Percent)
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000 006440000000
NAM: EGR
KO=0 LI=0-15 HI=32 OR=0-44 %
EGR Throttle Position Control Signal
TXD: 07E022096C
RXF: 04620509066C
RXD: 3010
MTH: 00647FFF0000
NAM: ETP
EGR Valve Position (mm)
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position.
EGR Valve Position Desired (%)
TXD: 07E02209D2
RXF: 0462050906D2
RXD: 3010
MTH: 00647FFF0000
NAM: EVD
EGR Valve Position Measured (%)
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve.
KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT
EGR Valve Position (Volts 0-5)
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT
Old Aug 18, 2013 | 01:53 PM
  #40
CPB1's Avatar
CPB1
These are also nice to have,
DTC Count (Diagnostic Trouble Code Count)
TXD: 07E0220200
RXF: 046205020600
RXD: 3008
MTH: 000100010000
NAM: DTC
Counts trouble code cycles
Fan Speed Sensor (RPM)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
KO=0 LI=533 HI=488 OR=0-4000
Fan Speed Sensor Duty Cycle (%)
TXD: 07E022091F
RXF: 04624509061F
RXD: 3010
MTH: 013103E80000
NAM: FDC
Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync)
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3000 (3001 alternate)
MTH: 000100010000
NAM: SYC
KO=0 LI=1 HI=1 OR 0-1 (NO/YES)
Old Aug 18, 2013 | 02:11 PM
  #41
JWREO's Avatar
JWREO
ok so new symptom after cleaning EGR... while cruising still has miss, if i let of pedal and then try to accelerate there is no response at first black smoke pours out exhaust, then she catches up and away we go happens every time i slow down and try to accelerate.
was watching EGR on gauge no just read 0 whole time
Old Aug 18, 2013 | 03:19 PM
  #42
jswartz84's Avatar
jswartz84
I think it has to be to a certain temp before the egr valve will start moving. Mine would typically start after about 8 minutes of driving. The black smoke and throttle response problem you are seeing was the same symptoms I had before I did my delete. You can monitor the EVD and EVM values and they should stay pretty close together. Turns out my valve did not follow the commanded position very well.
Old Aug 18, 2013 | 03:24 PM
  #43
BLADE35's Avatar
BLADE35
Post these Sensor info below it will help Diagnose why you have the DTC P2262
The P2262 must be taken care of and Solved before Moving On
<table width="826" dir="LTR" border="1" cellspacing="0" cellpadding="7"><tbody><tr><td height="3" valign="TOP" colspan="3"> Truck in park or neutral at all times during the test
</td></tr><tr><td height="3" valign="TOP" colspan="3">ECT at 190* or close to And EOT at 185* or higher
</td></tr><tr><td width="33%" height="3" valign="TOP">A/C Off
</td><td width="33%" height="3" valign="TOP">Created by Piolet
</td><td width="33%" height="3" valign="TOP">3/17/2013
</td></tr><tr><td width="33%" height="3" valign="TOP">KOEO = Key On Engine Off
</td><td width="33%" height="3" valign="TOP">Updated
</td><td width="33%" height="3" valign="TOP">3/25/2013
</td></tr><tr><td height="3" valign="TOP" colspan="3">Low Idle = Let truck idle on its own
</td></tr><tr><td height="3" valign="TOP" colspan="3">High Idle = 2,500 rpm
</td></tr></tbody></table>
BARO
MAP
EBP
VGT%
Now when you drive the truck and smash the pedal to the Metal Check out Boost PSI and Post what the Highest Boost PSI you get. This will help see if the turbo is working
Old Aug 18, 2013 | 03:28 PM
  #44
BLADE35's Avatar
BLADE35
Might be the SGII X-Gauge Code or some the early trucks wont show that EGR gauges
Old Aug 18, 2013 | 03:35 PM
  #45
CPB1's Avatar
CPB1
Black smoke is unburnt diesel fuel. It sounds like there is fuel getting passed one of the injector O-rings. That's what it sounds like, not saying that's what it is.
What EGR code are you reading? You can read EGR desired vs EGR measured.
Also check the DTC count, see if there are any codes.
