Some some help troubleshooting round two
Old Aug 19, 2013 | 11:31 AM
  #61
JWREO's Avatar
JWREO
Originally Posted by JWREO
KOEO:
BAR 14.3
MAP 14.2
IDLE:
BAR 14.3
MAP 14.4
EBP 14.6-16.2
VGT 85
2500RPM
BAR 14.3
MAP 17.2
EBP 20.6
VGT 50
BST in park throttle mashed 11.2
After more reading I find that EBP should remain within .5 of BAR, my readings at idle were up and down, should they have remained steady?
Old Aug 19, 2013 | 12:21 PM
  #62
mustang_309's Avatar
mustang_309
The MAP, EBP and BAR at KOEO should be within 1.5 PSI of one another at KOEO as they are reading atmospheric pressure. When the engine is running the EBP and MAP will change. I have read the MAP, BAR and EBP need to be within .5 PSI of one another but have also read that they are supposed to be within 1.5.
Old Aug 19, 2013 | 01:18 PM
  #63
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
That's KOEO (key on, engine off) once the engine is KOER (key on, engine run) things change and of course you'll see higher EBP and MAP as the engine is pushing out exhaust and making a small amount of boost at idle.
As long as your VGT % responds to throttle you are looking good. If it remains @ 80+% at all times then you have issues.
One thing you could do, even though it looks like your EBP sensor looks ok is to go ahead and clean it along with the EBP tube.
Josh
Old Aug 19, 2013 | 01:35 PM
  #64
JWREO's Avatar
JWREO
For whatever reason I can no longer get a BAR reading I have tried two different programs what sensor delivers that info?
Old Aug 19, 2013 | 02:33 PM
  #65
JWREO's Avatar
JWREO
interesting find... If I disconnect map sensor it defaults to 2.8 and vgt rests at 70, i disconnected BAR sensor, blew air into plug.. I now have BAR readings back. LOL (realy pounding head on desk) Ive got to get some work done today... When I get home I will vacuum out EGR, and clean EBP and see what happens, I know the turbo is working on way to work this morning I romped on it and watched boost gewt 28 before I had to let off.
Old Aug 19, 2013 | 07:33 PM
  #66
JWREO's Avatar
JWREO
EPB Cleaned, Waiting on EGR O-rings and gasket, MAP is clean. BAR sensor is intermittent and is driving me nuts. Engine is idling better still has a miss 1100-1800Rpms doesn't seem as bad though. I haven't had any new codes. VGT like to stay 85 at idle but responds to the slightest touch of throttle. On the hwy today when she got warmed up I stomped the pedal....took a good second or two to respond, turbo spooled up and bst maxed out at 27.4. FICM stayed at 48 ICM climbed with throttle wasnt watching real close where it topped out at.
Old Aug 19, 2013 | 07:46 PM
  #67
BLADE35's Avatar
BLADE35
Sometimes its helps to get a DTC
Does thing get worse when that Baro gauge drops off
Its weird about Baro That Sensor has been Good for Folks for most part
And has any of your Numbers from Post#61 changed since you cleaned up all those sensors??
Maybe your waiting for that Gaskets so when you can run it
Old Aug 19, 2013 | 07:50 PM
  #68
BLADE35's Avatar
BLADE35
ICV KOEO: .23
ICV at idle: .72-.82
Post IPR% with ICP & ICPV
ICPV Shure Seams Low @.72 at Idle and it Looks like electronically Your ICP Sensor is Good
Old Aug 19, 2013 | 07:57 PM
  #69
Bullitt390's Avatar
Bullitt390
.72 is roughly equal to 555 psi.
Josh
Old Aug 19, 2013 | 08:12 PM
  #70
JWREO's Avatar
JWREO
KOEO
WT 182F
EOT 26.8?
IPR .23
ICV .23
MAP14.2
EBP 14.3
BAR ----
KOEO
IPR .74-.82
ICV .74-.82
ICP 575-588
Old Aug 19, 2013 | 08:13 PM
  #71
JWREO's Avatar
JWREO
Low ICP= HPOP leak?
Old Aug 19, 2013 | 08:18 PM
  #72
mustang_309
Your IPR is not right, it should be a value of 14 to 84%
Old Aug 19, 2013 | 08:28 PM
  #73
BLADE35's Avatar
BLADE35
Your IPR Gauge is really ICPV Code
IPR Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM: IPR %
Old Aug 19, 2013 | 08:36 PM
  #74
JWREO's Avatar
JWREO
KOEO 16.8
KEOR 17.2
I entered wrong commannd, is the EOT command set to read Delta?
Old Aug 19, 2013 | 08:52 PM
  #75
Bullitt390's Avatar
Bullitt390
KOEO 16.8
KEOR 17.2
That is your IPR%?
Josh
