IDIT Performance Build
Old Jul 10, 2013 | 10:50 PM
  #196
88 Ford IDI's Avatar
88 Ford IDI
Some of them are but not everyone who is above 20+psi are running those cams. Also Racin's cam doesn't really drop dynamic compression that much. Iirc it is only around a point...
Old Jul 22, 2013 | 07:18 PM
  #197
xcite's Avatar
xcite
Update:
New roller rockers are finally here, will be measuring for push rods tomorrow and get them ordered.
Old Jul 22, 2013 | 07:46 PM
  #198
Bonanza35's Avatar
Bonanza35
Looking good. Keep us up to date.
Old Jul 22, 2013 | 07:54 PM
  #199
Ford F834's Avatar
Ford F834
Wow. Those look bad a$$! Very nice!
Old Jul 23, 2013 | 01:49 AM
  #200
Brant Bowrifle's Avatar
Brant Bowrifle
Bad a$$ is right, pricy little fellas. I'm not sure I'm convinced they will make a noticeable difference, but looking that good who cares?
Old Jul 23, 2013 | 06:48 AM
  #201
goose_ss4's Avatar
goose_ss4
sexy for sure
Old Jul 23, 2013 | 11:46 AM
  #202
88 Ford IDI
I have seen a dyno of a Cummins that had Harland-Sharpe roller rockers and the peak power and torque difference wasn't huge but the difference down low was actually pretty big. The dyno didn't start until around 2k rpm but the space between the old dyno was pretty big. I don't remember the exact numbers but it was pretty eye opening...
Old Jul 23, 2013 | 11:57 AM
  #203
88 Ford IDI
If anyone wants to see that article it was in Diesel World a few months ago.
Old Jul 24, 2013 | 01:40 AM
  #204
racer30's Avatar
racer30
Very Nice....The Improvement in Accuracy and stability will be measurable but not a Big power mod. If you did back to back engine dyno runs you would see a difference in performance over stock Mostly its for reliability and pure coolness... You win just because nobody has them.
Old Jul 24, 2013 | 03:21 AM
  #205
ozdatman's Avatar
ozdatman
They stop a lot of side loading on the valve stems, which reduces wear on the guides. reliability is always a good side benefit.
Old Jul 24, 2013 | 04:21 PM
  #206
hairyboxnoogle's Avatar
hairyboxnoogle
Exactly, and that is an issue especially for the 7.3. Wont see anymore cracked / chipped valve tips anymore i bet.
Old Jul 24, 2013 | 07:02 PM
  #207
Wood.'s Avatar
Wood.
beautiful, those should definitely add some valve train accuracy, should be able to pull more rpm out of it.
so since you had these made is there some data for them, can they be reproduced fairly easily now?
would you mind posting a cost?
Old Jul 24, 2013 | 08:24 PM
  #208
xcite's Avatar
xcite
Harlan Sharp makes them, you can get them in 1.5, 1.6, and 1.7 ratios.
As far as cost you would have to call them and get a price now that they have made a set.
The main reason for me in buying them was for reducing the stress on the valve terain. I have lost an engine before after breaking off a valve tip sending the valve into the engine. The price of the rockers is less then the cost of getting my truck hauled back home from a great distance away so it makes economic sense to me. Not to mention the cost of repairs from such a failure.
Old Jul 24, 2013 | 09:13 PM
  #209
goose_ss4's Avatar
goose_ss4
oh and you forgot the compleet old school badass of them
Old Jul 24, 2013 | 09:22 PM
  #210
goose_ss4's Avatar
goose_ss4
new diesels now are running valve releifs in the pistons in aftermarket pistons and such for valvetrain. Well this lead for more options for us via airflow/cfm? without extensive head modifications? I know racin was looking into his heads upgraded, but what about a high lift motor on high engine compression?
thoughts
