IDIT Performance Build
Old Jun 30, 2013 | 10:46 PM
  #181
300-6 AUTO TECH's Avatar
300-6 AUTO TECH
Originally Posted by xcite
Well I made it out to SD towing my camper today, over 400 miles. The truck pulled the camper with ease and power to spare. Hills that in the past would have down shifted me out of overdrive and slowed me down where not even a problem and never came out of OD. Cruising 70-75 thru the flat country and mild rolling hills boost ran between 8-12 in the flats and mild hills ran 10-16 with egts ranging from 800-1000. When hitting the steaper longer hills that would have slowed me down in the past boost ran between 18-22 with egts peaking around 1100-1150 max.
I still need to do some adjustments to throttle sensor and possibly timing but over all the truck ran very well. I will be checking the truck all over tomorrow just to double check everything after the trip.
Those are great numbers for a real world tow scenario. That's awesome to hear man. I will have a very similar setup when it's all done. Sounds like It's all working together really well. You got me itching for an A3K of my own.
Old Jun 30, 2013 | 11:20 PM
  #182
88 Ford IDI's Avatar
88 Ford IDI
Your setup sounds awesome man. Really good egts. Any videos yet???
Old Jun 30, 2013 | 11:27 PM
  #183
xcite's Avatar
xcite
Nope no videos yet, son took the last one and I am a poor narator.
Old Jul 1, 2013 | 06:56 PM
  #184
FORDF250HDXLT's Avatar
FORDF250HDXLT
Exclamation caution!
that's insane.i can't even do that running empty (granted empty is still 8k lbs.)
can you define "hill" as noted here,the gross combined weight,and also provide the tps settings at both idle and wot?
Old Jul 1, 2013 | 07:13 PM
  #185
xcite's Avatar
xcite
Gross weight was roughly 14800-15100. The hills I am talking about are the ones in south west minnesota and east and northeast South Dakota. Just alittle below having to be rated with signs but are several miles long on many of them. I dont remember exact settings on sensor but idle was approx 1.24-1.26 from memory. I know wot isnt quite set right as I have to lift off accelorator to get it to shift into OD.
Old Jul 1, 2013 | 07:37 PM
  #186
NMB2's Avatar
NMB2
he also has nearly twice the power of your truck. I pulled all grades through the cascades and rockies in od @ 65-75mph
Old Jul 1, 2013 | 07:53 PM
  #187
FORDF250HDXLT
very impressive guys!
Old Jul 1, 2013 | 09:29 PM
  #188
Bonanza35's Avatar
Bonanza35
I'd say you are set up prefect for what you have. glad to hear how you did so far. Now come to CA and build my Van!
Old Jul 1, 2013 | 11:02 PM
  #189
Leftyizme's Avatar
Leftyizme
Thanks for the interesting thread. Having recently purchased my '94 IDI Turbo CC Dually.. I wish I could afford at least some upgrading.
Does give me something to dream about getting someday..lol
Old Jul 9, 2013 | 10:35 PM
  #190
Wood.'s Avatar
Wood.
i keep reading of builds with 25+ lbs of boost what is being done to create this much power without blowing the head gaskets? i realize studs, but safely going from 10 to 25 with studs and new gaskets? that seems like a lot.
what did you do xcite? i read that you removed some from the piston, but also decked the block, were the heads surfaced also? stock head gasket? intake manifold studs?
also did you sleeve all 8?
Old Jul 9, 2013 | 10:37 PM
  #191
NMB2's Avatar
NMB2
Studs and stock gaskets
Old Jul 9, 2013 | 10:50 PM
  #192
88 Ford IDI
^^^ This. RacinNdrummin hit in the mid 30psi range with stock compression and NMB2 hit almost 40psi with lowered compression. There are even a few running over 20psi with stock bolts. I wouldn't recommend that as much though. Lol. Anyway with studs and bolts and stock compression you can easily run that much boost with no issues. Another thing you would need to upgrade would be the turbo. One of the turbos produced for these engines could do it but it won't be as efficient at that boost. It would heat up the air quite a bit...
Old Jul 9, 2013 | 11:01 PM
  #193
hairyboxnoogle's Avatar
hairyboxnoogle
In short you need studs, pump and turbo.
Old Jul 10, 2013 | 06:32 PM
  #194
Wood.'s Avatar
Wood.
thank you for the quick replies.
sorry for the thread jack. love the build, inspirational...
Old Jul 10, 2013 | 09:08 PM
  #195
92F350CC's Avatar
92F350CC
They're also running cams that bleed off some of the compression. It works.
