Bulletproof injector options
Old Mar 7, 2013 | 10:11 PM
LSAtexan4x4's Avatar
LSAtexan4x4
I am having issues similar to what I had before with my injectors... Stuttering, jerking, missing, hiccuping... I have just under 130000 miles on my truck and ford installed 2 injectors about 6 months ago... And it was awesome for about 10k now the same again... Are MC injectors the best option on the market or are there some better ones... I have had multiple issues with this truck in the 19k miles I've owned it and can't afford this forever but don't want to give up on it either... Appreciate the input guys!
Old Mar 7, 2013 | 10:35 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
What are you FICM voltages and what oil are you using?
Josh
Old Mar 7, 2013 | 10:42 PM
LSAtexan4x4
47.5-48.5. Rotella 15w40
Old Mar 7, 2013 | 10:51 PM
Piolet's Avatar
Piolet
I understand there's a lot of reasons that go into why something happens to one truck and not another ... so with that being said I have 273,000 miles on all 8 original ford injectors. I'd call that pretty bulletproof.
Old Mar 7, 2013 | 11:16 PM
LSAtexan4x4
Did you buy new?
Old Mar 7, 2013 | 11:35 PM
Piolet's Avatar
Piolet
Originally Posted by LSAtexan4x4
Did you buy new?
I bought it in 2007 with 100,000 miles.
I haven't done any of them in the 173k I've owned her. They weren't on the oasis report and the other records I got with it suggest they weren't done.
I've had the top opened twice for head gaskets and a HPOP since then. All same injectors went back in.
Old Mar 7, 2013 | 11:38 PM
LSAtexan4x4
I have a guy at work has 170k on his and hasn't done anything to it... Just brakes... He bought it new in 05... Mine was owned by a company prior to me having it.. I wonder if they blew off the highly important maintenance for it
Old Mar 8, 2013 | 02:41 AM
Yahiko's Avatar
Yahiko
Maybe a silly question but have you installed the Blue Spring kit and checked the fuel pressure?
Low pressure will take out injectors. Dirty filters will also lower the pressure.
Sean
Old Mar 8, 2013 | 04:31 AM
bismic's Avatar
bismic
IMO people using 15W40 oil are far more likely to develop stiction issues than folks that use 5W40 or 10W30 oil. 15W40 should not be used in the winter - Ford says not below 20 degrees (some argue the number is 30 degrees).
Old Mar 8, 2013 | 05:27 AM
MC5C's Avatar
MC5C
The engineer I spoke with at Ford head office told me 50 degrees cold soak temp for switching to 5W-40, so that's what I do, FWIW. Helps to have a sister at Ford who can hook you up with the right guy at the right time... Losing injectors can very often be fuel pressure related, I lost three in 200 miles when my fuel pressure dropped to 40 psi under full load. If you don't have the blue spring and a verified 50 psi plus at full load, then fix that issue and change the injectors.
Old Mar 8, 2013 | 07:00 AM
bismic's Avatar
bismic
Thanks for the post MC5C
Old Mar 8, 2013 | 07:09 AM
LSAtexan4x4
MC5C thanks! Good info. I did the blue spring about 8 months ago.... I went to 5w40 a couple changes back with no obvious benifit... I also tries the hot shot secret additive. I don't have a fuel pressure gauge so shame on me there... Why are these injectors so finicky with al this.. Why would they stop working? Just strictly lubrication factors?
Old Mar 8, 2013 | 08:19 AM
Piolet's Avatar
Piolet
Fuel pressure is a good one to have.
Get yourself this accessory from Strictly Diesel ---> Driven Diesel 6.0L Fuel Pressure Adapter
One end screws into a port right where you did the blue spring. The other end is where you attach your fuel pressure sensor. Then from the sensor you can clip in the harness or pigtail from what ever gauge/sensor setup you bought and run it to the gauge in the cab.
You can run the wiring to a typical stand alone 2-1/16" round gauge, or to an accessory attachment on the Edge CS or CTS if you already own one.
I think there's other electronic gauges that will take an external sensor and display it on their screen. Others will let you know I'm sure.
Old Mar 8, 2013 | 02:17 PM
LSAtexan4x4
Im going to do my fuel filters today just to see what happens its been about 8500 miles since I did em last
Old Mar 8, 2013 | 02:18 PM
LSAtexan4x4
And just for the record I live In San Antonio tx it's been in the 30s maybe 2 times
brian42
33
Jan 17, 2018 11:24 AM
RenoHuskerDu
33
Oct 25, 2017 08:31 PM
Roasted7
Sep 27, 2012 11:18 AM
timothyr
Dec 31, 2009 11:21 AM
Ratkat
Jul 17, 2008 07:21 AM
