Am I Going Overboard Replacing the Cups While I Have The Injectors Out???
Going to pull the injectors next week to replace the failing O-rings. I'm burning 1 quart of oil every 100 miles and everything points to the injector o-rings (https://www.ford-trucks.com/forums/1...-band-aid.html).
The truck has 306K miles and I've never touched the injectors until now (I've owned it for 160K miles). I am considering replacing the injector cups since they've been in there for 15 years. I don't have any indications of cup problems but with everything apart I am leaning towards doing them as a preventive measure. Am I overthinking things? Am I paranoid? Am I the smartest person alive?
Also, what brushes do you guys recommend for cleaning out the bore for cups and/or injectors? I see that Riffraff has a couple of Alliant brushes (for injectors I think) and they are over $50. While I'm sure they are a perfect fit is there a kit that will cover things with more brushes for a better price. I remember seeing a couple of kit names/numbers in all the cup/injector threads I've been reading over the last week but don't know where I wrote them down at.
I changed my injectors around 300k just because I had the time, the weather was nice, and everyone said they should have already failed by then. Turns out I got no benefit from the new injectors other than a lighter wallet (and the part about them not failing at some point in the future).
I left the original cups alone when I put new injectors in. 560,000 miles on the truck now and the son in law is driving it with no issues or signs of leaking cups.
on
I appreciate the feedback. I plan on keeping the truck until it dies so every time I go into something I try to do as much preventive work as my time (and wallet allows). It's easy to get caught up in the car salesman's "for just a few dollars more a month..." pitch. Once I park the truck to work on it everything seems to be interconnected and my mind starts to make a long list of things to do, then my wife let's me know what our wallet can do, then everybody here lets me know what I should do.
Thanks for the replies. Cups are off the list.
Good to hear, brian42. I was squiggling with the same "back of my mind" question as I still look forward to shimming and ringing my existing injectors. My gut was telling me pretty much what everyone else advised, and all of the collective experience and advice has confirmed that I also will NOT consider cups unless I see evidence of a true need when I pull the injectors.
306K miles (my gut) was telling me just get some cups and get it done while they are sitting there, exposed and lonely (I had to wait for injectors anyway). My wallet and my watch were telling me you've already spent enough moolah and time on this thing (parked for 2 months and counting) so why do something that doesn't need done?
This is why: https://www.ford-trucks.com/forums/1...tor-cup-s.html
Too bad I don't like Snickers...I'm not going anywhere for awhile.
I should have gone with my gut.
Don't forget to take a lot of pictures and notes about your experiences with the tools and cleaning the old loctite out and what not. I will be reading your thoughts many, many times as I am staring at these same maintenance tasks.
on
I was one of the ones who said don't open a can of worms if you don't have to...sorry for that, too
Hopefully they will be much easier than it appears and others have reported!
I've notice that there's been alot of injector cups failures lately since everybody has been converting to ELC? Maybe it's not only the e99 or older 7.3's that get affected by ELC eating the injector cup sealant maybe it's due more to the age of the sealant itself and not the ELC eating away??? I don't know but since I changed to ELC on my work truck I've noticed that the Degas bottle has darken a bit since the switch, with a very small hint of diesel smell......
Forgot to add mines an 01 with 406k
