Project Wicked Bad *** !
Old Mar 1, 2013 | 04:35 PM
  #106
cbakker's Avatar
cbakker
I think there is enough room behind the bumper to lift it up a little bit.
After you drop your body back down a little bit, it wouldn't take much lifting of the bumper to close that gap.
You seem handy enough to get the job done.
Old Mar 10, 2013 | 09:38 PM
  #107
firerescue9's Avatar
firerescue9
Okay yall, i need a little help on this one.
Today i went thru a couple mud trails and got pretty deep. But shes faithful and we go ***** to the wall when need be. Didnt get stuck once!
Of course theres always aprice to pay.
So I pull into the drive way when we get home and my brakes go out; Pedel went to the floor. I tried to figure out what it was and by the looks of the passenger tire being soaked, a bad caliper. Which sucks because i JUST bought calipers for my D60 axle, but i dont have all the parts for a SAS yet =(
Next is the what im confused on.
As im looking for leaks in the brake lines i notice this and a small (2in diameter) puddle under it. This is the pitman arm. Im assuming that gap between pitman arm and the steering box isnt a good thing....?
I never noticed before. Does this mean i need a new steering box? I mean like i said i never noticed while driving any difference.
Old Mar 11, 2013 | 04:54 PM
  #108
Puddy's Avatar
Puddy
Looks like you blew the seal
Old Mar 11, 2013 | 05:32 PM
  #109
firerescue9
Does it mean i can press in a new seal or do i need a whole new steering box? I wonder if the one off tthe F350 would be the same ...hmmmmm ill have to look into it
Old Mar 11, 2013 | 06:15 PM
  #110
SideWinder4.9l's Avatar
SideWinder4.9l
You'll need to-
  1. Remove the Steering Shaft from the upper portion of the steering box.
  2. Remove the 2 PowerSteering Hoses from the Steering Box.
  3. Remove the Steering End link that connects to the Pitman Arm
  4. Remove the actual Steering Box from the frame
  5. Use a Pitman Arm Puller to remove the Pitman Arm
  6. Undo the bolts, snap rings (Total PITA), etc and replace the blow seal.
    Then put everything back on in reverse order.
    The actual Lower Steering Box Seal kit is like $7-8...
    If I remember correctly on the tools/sizes-
  • Steering shaft uses a 6pt, 13mm socket.
  • The High Pressure Power Steering Hose uses a 1/2" Line Wrench
  • The Low Pressure Power Steering Hose uses a 5/8"? Line Wrench
  • The Castle Nut that holds the Tie Rod/Drag Link on is a 11/16"? Socket
I just replaced the entire font steering components on my dads 1992 F-150 the other day....And have forgotten a lot of the sizes..:/
Total time replacing that seal should be around 1.5-2 hrs..Ish..lol
Old Mar 12, 2013 | 07:39 AM
  #111
Encho's Avatar
Encho
The Southernmost Mod
Side makes it sound too easy and fast... It isn't. Read the Steering Box Rebuild link in my signature to get an idea.
Old Mar 12, 2013 | 07:46 AM
  #112
SideWinder4.9l
Originally Posted by Encho
Side makes it sound too easy and fast... .
Nothing is ever as it seems with these old trucks....lol
Old Nov 24, 2015 | 12:28 PM
  #113
1989f250xltlariat's Avatar
1989f250xltlariat
I know this is a very old thread but does anyone know how/where to get those black headlights??????
Old Nov 24, 2015 | 12:38 PM
  #114
SavageNFS's Avatar
SavageNFS
Here is one way to tint them yourself
Not sure I recomend tinting them on the vehicle, but it gives you an idea.
https://www.vhtpaint.com/products/niteshades/
Old Nov 30, 2015 | 01:48 PM
  #115
1989f250xltlariat
How to Tint Tail lights - Night Shades - YouTube
How-To Tint Your Taillights With Nightshades - YouTube
Thanks A bunch man!!
Old Dec 6, 2015 | 09:47 PM
  #116
Puddy's Avatar
Puddy
.... headlights.....tinted.....
Old Dec 7, 2015 | 01:26 AM
  #117
eagle275's Avatar
eagle275
I want mine as bright as I can get, in fact I'm looking for some really bright LED's. I wish someone made a complete replacement LED tail-light for our trucks! I want that person behind me that's driving a guided missile and playing on their cell phone to notice me, especially when they've been drinking or getting high,eh. I gues I learned a few things when driving big trucks cross-country.
Old Dec 7, 2015 | 09:04 AM
  #118
1985 Bronco's Avatar
1985 Bronco
It looks like those are headlight covers, NOT tinted headlights
Old Dec 7, 2015 | 09:22 AM
  #119
1985 Bronco
http://www.carparts.com/details/Ford...FQaraQodVvQNYQ
R_Stalhandske
Aug 7, 2018 08:54 AM
Monstermax4
Aug 5, 2017 06:53 PM
HIO Silver
44
May 2, 2016 07:43 PM
housedad
Garage & Workshop
Sep 20, 2013 08:30 AM
thomae06
1997 - 2003 F150
30
Dec 11, 2008 11:05 PM
